Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By arzaam.bhatti
Thread: After market air filter/intake for Honda Fit hybrid review
    deltoid61's Avatar
    Oct 2006
    36
    236
    9 Post(s)
    Exclamation After market air filter/intake for Honda Fit hybrid review
    Salam all.i just wanted to share my experience with after market intake whihc i used on my honda fit hybrid.
    the reason why i imported is becuase this car uses oil bases filter whihc is rather very expensive.Rs4500 per filter.you can use normal cheap ones but i am talking about honda recommendations.As company says to change it after 10,000 Km so i thought i will have to chnage it after 2 oil changes.but
    even after 1st oil change it was so dirty.so i thought instread of buying 4500 Rs filter every oil change why not import a K&N filter which is washable and reusable and is for life time.
    so i imported and an after market intake also.costed me RS 27000.Its USA based company HPS short Ram intake with K&N oil filter but i did one mistake.as there was no specific filter for hybrid so i imported the filter of normal Honda fit and thought it will work.
    it did fit accurately but the ECU showed CHECK engine light after few runs. i reset the ecu many times but again after some time error comes. with scannenr the code was"too rich air fuel mixture"
    So my advice that modern Honda ECU are very smart.even a small change in air flow rate etc and they will throw a yellow light at you.
    So my advice untill you are importing exact model part for your car dont risk it.or use some tuning soluton for your new bolt ons.
    I have now imported AEM-FIC for tuning and a turbo kit for my fit.so for me it wont trouble any more fo me.
    but you people do watch it when importing after market engine parts especially performance parts
    {{((( Impossible it self says 'I' 'm' 'possible' ))}}}
    Never Give Up Hope
    arzaam.bhatti's Avatar
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    these lifetimes filters are crap, there is no such thing, and the only way they give improve airflow is by having bigger holes in the element meaning more dirt and debris can pass through, maybe some debris knocked out your MAF and you may need a new one now. its best to not mess around with factory specifications. if these were really so good you would see porsche, bmw etc installing them in cars where they follow extremely long intervals in servicing. stick to the original product, and for your existing check engine light did you note the error code before clearing? or simply disconnected the batteries? disconnecting battery trim IMO doesnt work on this or more modern cars you'll have to fix the fault.
    If everything is coming your way, you're in the wrong lane!
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    Well in order to compenate extra amount of air induced you will have to Install after mkt piigy to adjust atleast AFR so its better to stick wth stock air filter as hybrids are not meant for such mods,
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    deltoid61's Avatar
    Oct 2006
    36
    236
    9 Post(s)
    i reset the ecu with obdII scanner.still CEL came.i have imported piggyback AEM fic.ans a turbo.i will update when installes
    Never Give Up Hope
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    Quote Originally Posted by deltoid61 View Post
    what code was the scanner showing for check engine light maybe we can help,
    hmm turbo on a hybrid should be interesting how you integrate all that with honda's IMA
    deltoid61's Avatar
    Oct 2006
    36
    236
    9 Post(s)
    i have uninstalled the aftermarket filter and the CEL is gone.car runs fine now.but man she ran like a beast on HPS SRI.and sound was so gorgeos but na thi hmari qismat :p
    btw GP4 have mugen muffler already.it also sounds amazing.
    thanks azaam.bhatti for offering your help.JazakAllah
    Honda IMA operates in conjunction with car ecu.ahh i dont have words to make you understand but it will work inshaAllah.i already did istakhara and it turned very well.
    first my intention was to supercharge it.that was easy but i did istkhara and i was guided to turbo route.
    zeeshanhashmi's Avatar
    Nov 2007
    37
    85
    2 Post(s)
    Salam deltoid61
    How did you import - I mean if you ordered it on some website etc ? I want to import similar items for my Vezel.
    deltoid61's Avatar
    Oct 2006
    36
    236
    9 Post(s)
    Quote Originally Posted by zeeshanhashmi View Post
    Salam deltoid61
    W.salam bhai.i imported it via maxpowermotorsports. its safe that way. mine is for sale BTW as i have k20 swaped my honda fit.
    meanwhile i discoverted that if we vent PCV valve into air,the CEL no more comes but STFT's are rich still,like 18-20.so car still consumes more fuel on after market intake
    Never Give Up Hope
    Nov 2006
    29
    4,959
    12 Post(s)
    Best buck for these cars considering our environment are HKS Hybrid Air filter drop in type and HKS Oil Filters. Oil bathed filters not suitable for our dusty enviornment. Iv been using them in both our GP4 and GP5 Fits. Best thing is car use to knock on local filters if Super poured but now it isnt as Finding Hi Octane is hell of a luck. How to import them? Google it and you are going to find many links I got ones myself from Singapore.
