Results 1 to 4 of 4
Thread: Honda CR-V not starting ( No spark )
    faiz.aslam.121's Avatar
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Default Honda CR-V not starting ( No spark )
    Salam.
    Honda CR-V 98 mod 4AT not starting, whilst trouble shooting, spark came twice, after that, no spark. Thought it was the distributor at fault, ordered a used one and still same problem - spark a few times, then it's dead. Anyone got a clue?
    The distributor is not at fault, have another car inside, same everything and the distributors work on each other. Changed spark plugs as well.
    Turbo lag is like foreplay. You know it's coming. And it's gonna be good.
    roonjha's Avatar
    Jan 2007
    45
    53
    what about IG coil. check 12 v to coil, ground to coil?
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Quote Originally Posted by roonjha View Post
    Checked that as well.
    Slight suspicion that the ECU can be gone for the motor, we have another identical car, will change ECU and see
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Crank position sensor fault maybe
