Results 1 to 8 of 8
Thread: Honda Airwave 2006 Problems
    mzakj's Avatar
    Nov 2012
    26
    132
    Default Honda Airwave 2006 Problems
    1. I bought an Airwave recently and it has a strange problem. 6 out of 10 times when I turn the ignition, it does not start, no clicking sound, nothing. If I hold the gear button and give it a little push into P again, it starts then. Sometimes I have to do the little gear movement twice or thrice until it works. What can be causing this problem and what is the solution?
    2. Whenever I start the car in the morning and whenever I rev the car (in N or P), I hear this water-like sound (sloshing, gurgling and sometimes bubbling). This sound isn't from the fuel tank as I got the fuel filled to the brim and the sound kept coming. I consulted with Kamran (Experience Autos, Khi) thinking that it might be air in the cooling system. He said that if it was air the gasket would have blown by now. It's been a few days since I bought the car and this sound has been there since before I bought it as well.
    Guys please help me out here I really need to get these issues sorted out asap. I would really appreciate help.
    mzakj's Avatar
    Nov 2012
    26
    132
    @Xulfiqar @capsat
    Kindly help me out brothers
    kkoool's Avatar
    Apr 2005
    35
    1,661
    Service transmission range switch and Neutral safety switch and you are good to go, it can be found under the gear lever housing(neutral safety switch) and on the transmission itself(Range switch). When you have removed the housing around the gear lever, clean all terminals.
    The water sloshing sound is common and nothing to worry about, it goes away after the thermostat is opened.Its the coolant going around in the heater core. its common in Honda cities, airwave etc.
    AE 86
    mzakj's Avatar
    Nov 2012
    26
    132
    Quote Originally Posted by kkoool View Post
    So no risk of the gasket being blown due to the water around the heater core?
    I don't want to get the gear housing and terminals cleaned from a roadside mechanic so can you please guide me to someone qualified enough for the job? Would really appreciate it.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    though am blind & deaf for PKDM HONDA, few JDMHonda Airwave have landed in family. This transmission limiter & protection switch corrosion seems a common trait. The other respectable member identified clearly & guided you in right direction.
    dial 0300 923 2821 Jamil autos at Shahrae Quaideen Karachi. they can do the job professionally. 10 am to 7.30 pm diagnostics charges apply. while at that place you can ask for coolant top up [ no tap water ]
    Quote Originally Posted by mzakj View Post
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    mzakj's Avatar
    Nov 2012
    26
    132
    much appreciated brother @capsat
    mzakj's Avatar
    Nov 2012
    26
    132
    Quote Originally Posted by capsat View Post
    I called Jamil Autos just now. The person there seemed somewhat blank when I asked him about the NSS. He seemed to know when I talked about a switch telling the computer what gear is it in. I hope they don't end up doing something wrong. Trusting your experience @capsat bro
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    the moment people like us identify the actual problem and make them understand, the mechanic class go on back foot and trick you around. Though i know them for 30 years the mind set is still the ' Ustaad type ' a whiplash is needed frequently.
