Results 1 to 11 of 11
Thread: need suggestions for headlights for Suzuki FX
    Jackie512's Avatar
    Mar 2011
    9
    Default need suggestions for headlights for Suzuki FX
    heylo guys ...
    im looking for suggestions to change my suzuki FX's 1987 headlights , rite now the are normal yellow sealed beams and it have become difficult for me to drive at night times so want to get rid off these current lights ,
    pls suggest me some good solution/alternates for my problem , all i want is powerful and bright headlights my location is karachi and plaza is not far from my place but i have very low info when it comes to headlights so need proper solutions/ options available under 3-4k budget...
    thanks!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    if your lights are clean, good and branded - install a relay wiring harness on them - Please get someone to do a good and clean job - not some cut up wires joined and taped together. The wires should have crimped/soldered connectors on the relay and headlamp connector. The negative for the lights should also be from a good ground source (like the battery itself).
    Your lights visibility will improve by many times - Once done, aim the lights correctly for proper front vision.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    /thread.
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    get the headlights of 2011 model carrry dabba. i have seen many fxs wid them and they look gr8. i think they fit without major alteration
    MGK
    MGK is offline
    MGK's Avatar
    Mar 2008
    26
    3,032
    81 Post(s)
    5 Thread(s)
    Quote Originally Posted by margallar View Post
    I would suggest the same. Alterations are not advisable for an old car.
    haali's Avatar
    May 2010
    Other
    669
    2 Post(s)
    ^^ same as above. new carry dabba has excellent bright lites
    Always remember, the best things in life are not things.
    Jackie512's Avatar
    Mar 2011
    9
    ahaaan ... any idea about the cost ? and where to buy it from if possible ?
    oh and wat about HID KIT for carry dabba lights ? will that work w/o any issue ? i might go for normal XEON bulbs as well
    Jackie512's Avatar
    Mar 2011
    9
    one more thing , do i need to do any electrical alteration / changes in order to Install HID kit ?
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    Quote Originally Posted by Jackie512 View Post
    yes you need to install the hid kit. i dont think you shud install it coz your wiring is probabbly weak and hids cannot be focused without good projectors
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    instead of HIDs - why dont you follow what I wrote, that way you wont be putting glare into others eyes, have proper beam pattern for good frontal vision. If you want to go the HID route - new lamps+Relay Kit+HID kit - and still have a blind car
    OR
    Just a relay kit and have a good light pattern.
    rashed.iq's Avatar
    Nov 2009
    174
    OR
    I think this is the best solution.
