Results 1 to 8 of 8
Thread: Bolan Modification!
    Zain_ul_Abideen's Avatar
    Oct 2010
    Wah cantt
    21
    Exclamation Bolan Modification!
    Guys!
    I want to install a completely new air intake kit.. suggest which brand to use and from where to buy in RWP or LHR?
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    hmm dont know how will u bear its sound n vibration under seat :p
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    Oct 2010
    Wah cantt
    21
    Default Bolan Modification
    Please suggest and leave every thing else to me.. thanx..
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    u can use a simota carby intake if u think u have sufficent space under the seat
    www.facebook.com/performancepartslahore
    Oct 2010
    Wah cantt
    21
    Default simota carby intake
    DUDE from where i can get this intake kit in RWP or LHR and what it will cosT?
    Nov 2006
    29
    4,959
    12 Post(s)
    Hmm means ur upto sumthing.
    carby filter wont fit though Cone filter would fit easily.Mind it you have to remove stock filter box and CNG aswell if you want proper gain.In case of cng Venturi u have install a jet inside teh filter like in Mehrans cng FF kit.
    Go for NGK BPR6EGP platinum plugs.After market plug wires. Other then this use good quality lubes.Get oil of rear Differential aka Hissa changed and of gear box.
    PPl usualy ignore rear end which makes alot of difference.
    Get Point of Coure in the Carb.
    The above will imrpove ur mileage on same time.
    If the engine of ur car is rebuild then i wont suggest any mod
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    ^^ Point of cuore in carb? can you please explain that a little.
    and to the original poster - the original air setup in your van is very good, do not think you can exceed it given the design limits
    Nov 2006
    29
    4,959
    12 Post(s)
    oh my bad Point of distributor.
    he will surely notice some difference after open filter under his seat :p
Tags for this Thread
