Results 1 to 2 of 2
Thread: Bolan Gear problem!
    Zain_ul_Abideen's Avatar
    Oct 2010
    Wah cantt
    21
    Exclamation Bolan Gear problem!
    I am having a problem with gear system of my Suzuki Bolan 1993.. The first and the fourth gear automatically jerks out during ride. Means e.g i have loaded 1st gear then it will automatically jerk out. And after 2-3 tries it will be loaded successfully , and same is the case with 4rth gear.. What should have been the problem?
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    syncronizer repair work inside gearbox will fix the problem
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
Tags for this Thread
