Results 1 to 12 of 12
Thread: Fx Radiator Modification?
    devilhimselff's Avatar
    Apr 2006
    Muscat
    43
    104
    Default Fx Radiator Modification?
    Guys can you tell me what Radiator I can put in Fx for better results, as its getting Hot. And I think that the Radiator in the Car is "desi" made. Anyways What Car's original (Qablee or New) will fit in the space in Fx and has more Pipping etc.
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    The most close match is the radiator of Mehran, you may get it for approx Rs.2500/=
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    Apr 2006
    Muscat
    43
    104
    @testdriver
    Thanks for the reply, but Meharans also get heated up
    So I was thinking about putting in a Radiator of Some Bigger Car (that has more Pipping) that can fit in Suzuki Fx. Will Mehran's Radiator do the Trick ?
    Mmmm I dunno, any suggestions.
    Thanks again.
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    My Fx is reducing water from Radiator. Phiscaly their is no leakage & its empties all the water in Extra bottle out side the radiator in just 30 to 40 Km drive & when water level goes low in radiatr it starts heating up which is due to deficiency of water. So what should i do ?
    Exploring Machines is my Passion...
    whiteangel's Avatar
    Nov 2005
    2,240
    9
    65 Post(s)
    imranbhatti
    If there is no apparent sign of leakage then I'm afraid the head gasket might need to be replaced. But do get it thoroughly checked by a good mechanic to confirm it.
    Never argue with an idiot, they drag you down to their level and beat you with experience.
    Apr 2006
    Muscat
    43
    104
    Well what bout Cultus's Radiator ? Will it fit in Fx ?
    Any ideas about the cost of a new one.
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    try a japan made radiator,from junkyard,,,,.
    i dunno if that is of any help.
    once u get a good radiator going.. always use a good coolant in it
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    zeeali's Avatar
    May 2005
    38
    106
    Its not necessary that your car's heating prob. is due to radiator only. i'll suggest you to consult your mechanic 1st then go to some radiator wala. in radiator wala's language they call "2 naali" or "3 naali" or more than that.... my radiator wala once suggested me to change my radiator from "2 naali" to "3 naali" locally modified one... but after having serviced my "2 naali" radiator it stopped soaking the water nor my fx is getting hot Mashallah.
    Therefore my recommendation is to get it checked from some good mechanic(s). I'll recommend to take advise from more than 2 mechanics as some times it helps.
    Regards,
    ALI
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    @imranbhatti
    if there is no aparent leak then the radiator cap is faulty... it has a spring and a rubber in it and when the pressure rises due to steam the spring compresses and the water goes to the bottle...
    change it and i think taht your problem will be solved....
    its all about power to weight ratio...
    robin's Avatar
    Jun 2005
    2,825
    i am not sure 2.0 D radiator will fit well in ur FX or not, but it fits well in charade etc. it's one of its kind. rugged and long lasting and smaller in size.
    btw, need to check 3 things
    gasket, water pump/ bearing , radiator cap/hoses.
    Apr 2006
    Muscat
    43
    104
    I will go to the Radiator Dude and check all the things suggested.
    Lets hope all gets fixed.
    Ill post what happened.
    Thanks again all.
  12. #12
    ifi
    ifi is offline
    ifi's Avatar
    Mar 2005
    36
    405
    radiator might not have any leakage but the pipe that goes into the engine might got a leak...
    as my car also does the same and i went to my mamoo's workshop and he found the issue in the pipe that goes into the engine, not talking abt the plastic pipe it was some lohay ka "L" shaped chota sa pipe
    btw i have a huyndai excel
