Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Xulfiqar
Thread: Working of Suzuki Bolan Carburetor?
    royzafar's Avatar
    Mar 2006
    51
    5
    Question Working of Suzuki Bolan Carburetor?
    AoA,
    I have a Suzuki Bolan 2010 model running on Petrol and CNG. As far as CNG is concerned, it controles the delivery of gas by the vacume created by the engine. But how the carburetor controls the flow of petrol?
    Regards and thanks in advance for the help.
    Roy Zafar
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    old school way - READ HERE & HERE
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    royzafar's Avatar
    Mar 2006
    51
    5
    Well, before posting here my question, I have already surffed these sites. But, I could not find the answer to the question that is fuel flow is controlled, Is it with the vacume or with some sort of needle, etc or both?
    Thanks!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3987 Post(s)
    94 Thread(s)
    6
    the carburettor also works with the negative pressure (vacuum) applied by the engine on the intake stroke. The metering is controlled by a needle, its the oldest style of carburettors, and your bolan has a small throat carb best combination for low down torque.
    royzafar's Avatar
    Mar 2006
    51
    5
    It means, how much fuel is needed by the engine is controlled by the vacuum generated by the it in the carborator.
    Thanks for help!
    royzafar's Avatar
    Mar 2006
    51
    5
    I have talked to a auto mechanic and he says that there is needle valve in the carburater to control flow of the petrol.
    Any comments plz.
