Results 1 to 13 of 13
Thread: Suzuki Bolan Starting problem on petrol
    danishijaz's Avatar
    Feb 2012
    160
    2 Post(s)
    Default Suzuki Bolan Starting problem on petrol
    it is hard to start cold engine on petrol... after long self the engine starts but if i accelerate, then engine starts shutoff. so i can accelerate after 3-4 min till engine warms a little.
    Strange thing is that cold engine starting problem is only on petrol,,, on CNG it starts within half self... so its easy to start it on CNG in murree and hard to start on petrol....kindly suggest me solution....
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    Normally , starting on petrol is more easy as compare too CNG...
    this problem is happened with faulty fuel pump
    Pakistan <3
    murtazee's Avatar
    May 2009
    38
    1,402
    3 Post(s)
    wats the model of Bolan
    The time you enjoy wasting is not wasted time.
    danishijaz's Avatar
    Feb 2012
    160
    2 Post(s)
    its 2005 model and well maintained engine....this problem appears only when engine is too cold (cooled engine of one night) and problem vanished after 3-4 min engine start without accelerating engine
    danishijaz's Avatar
    Feb 2012
    160
    2 Post(s)
    Fuel pump is fine as there is no problem after engine gets normal temperature. even there is no any jerk or missing at highest speed of 110-km/h
    t4tufail's Avatar
    Jan 2013
    Manshera
    hard start on petrol
    causes
    un adjusted tappet
    hot type pluge installed
    faulty p.c.v vale
    danishijaz's Avatar
    Feb 2012
    160
    2 Post(s)
    Quote Originally Posted by t4tufail View Post
    causes
    un adjusted tappet
    faulty p.c.v vale
    Dear tappet are fine as if they are tight and lossing compression then how engine easily start on CNG.... and suzuki bolan has no PCV Valve. Plugs are new as i have replaced before a month and they are NGK,, i dnt knw about type of plugs
    t4tufail's Avatar
    Jan 2013
    Manshera
    Starting mein accelerator na lainy ke zyada tar 2 wajhein ho skti hain (jb k engine normal tempreature par na ho)
    1 , jam tappet
    2 , timing out
    cng ke timing 1 deg sy 24 tk jb k petrol ke sirf 1 sy 8 deg tk hoti hai
    aur mery khayal mein ap ke gaari mein yahe prblm hai shayad
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    next time - use the choke to start the engine. Also make sure the float level in the carburettor is correct.
    danishijaz's Avatar
    Feb 2012
    160
    2 Post(s)
    Dear Xulfiqar Brother: i have tried this, by using Chock or by pumping accelerator 3-4 times before starting gives me ease in starting engine but after using chock or pumping accelerator, i feel smell of petrol after starting engine. Engine accelerate normal by pulling chock but i don't know smell of petrol is normal or abnormal... i want to get rid of using chowk... is it possible?
    bilalahsan's Avatar
    Dec 2004
    46
    459
    6 Post(s)
    If your engine is dead cold first apply full choke, depress pedal twice then ignite . If your engine is warm turn key while half pedal is pressed. If your engine is hot turn key after fully depressing the pedal. I had similiar problems but when I learned how to start this way I never got problems again
  12. #12
    bilalahsan's Avatar
    Dec 2004
    46
    459
    6 Post(s)
    You cannot get away with choke. However just turn back choke off smoothly any gently and youwont get smells, fill proper coolant and oil grade as well
  13. #13
    mohdijaz's Avatar
    Apr 2015
    5
    Check carburator accelator pump 1st
