Results 1 to 7 of 7
Thread: Terios Kid Compressor For AC in Suzuki FX 1987 ?
    TheBighead's Avatar
    Feb 2013
    8
    Default Terios Kid Compressor For AC in Suzuki FX 1987 ?
    An AC shop guy suggested me to install Terios Kid compressor for my FX.... he says the results will be much better if we install this compressor... any ideas or opinions?
    ceecix's Avatar
    Oct 2011
    26
    68
    The compressor is good but with old compressor usually there is leakage in compressor seal. if u can can make sure that compressor is in good condition then go for it, in my fx i ran sanden setup for 2 yrs without any issue.
    Performance is the never ending game with never ending charm!!!
    dr3vil's Avatar
    May 2009
    11,928
    11
    201 Post(s)
    7 Thread(s)
    any 660cc competessor is good as it is rotary and puts less load on engine
    Hanjiii Kaa Storeey Eehh !
    TheBighead's Avatar
    Feb 2013
    8
    so do you recommend new sanden over old japanese compressor? Your opinions are most valued. Thank You
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Go for terios kid's compressor
    Body kits available for all cars...
    PM for details
    ceecix's Avatar
    Oct 2011
    26
    68
    well in terms of load terrios kid compressor is good as compare to sanden, just check its seals before installing.
    WAQAR602's Avatar
    Apr 2013
    Hi there, guys, i just installed terios kid used compressor in my mehran 2002 so far its working fine but the thing that makes me concerns is the heatup issue usually mehran doesnt have 2 fan in it. so the mechinic said to me there will be a heatup problem when u run continusely AC,
    any good suggestions to avoid heatup issues in mehran??
    let me know if u can
    thanks in advance,
    Jazak Allah
