Results 1 to 8 of 8
Thread: Dr.Frankenstein's attempt at FX semi-transplant
    ahsanonline's Avatar
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Exclamation Dr.Frankenstein's attempt at FX semi-transplant
    Here goes the story:
    - My FX has a screwed-up carburetor.
    - The valve cover has only one breather hose, air doesn't actually circulate like it does in PCV systems.
    I have thought up these options and so I need feasibility on these:
    1) Get a new carb - new chinese carb is costing Rs7000.
    2) Replace with a used carb from pak-suzuki mehran.
    3) Replace intake & exhaust with parts from the new euro-II mehran and do a carby-to-efi conversion.
    Any above option PLUS- replace the valve cover from a modern mehran so there is a proper PCV function.
    The biggest question is: Does FX have the same F8B engine as mehran; Are the intakes/exhausts/carbs/valve covers substitutable?
    Dr.Frankenstein calling suzuki experts~!
    Selling Vitz+local cars - compatible bluetooth Ecu Scantool, High-amp car chargers, Apple-certified Lightning Cables, etc. Click on my name and see my started threads for details.
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Seems like 125 viewers are afraid of frankenstein...
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    go ahead - no biggie
    AmirBilloo's Avatar
    Jul 2009
    28
    194
    bhai you got good writing skills but agar simple words app na query likh da ta to zadya expert replies mil ga ta
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    its the same Freaking F8b motor
    go ahead man
    Hanjiii Kaa Storeey Eehh !
    aatir.sheikh1's Avatar
    Jun 2013
    25
    Quote Originally Posted by ahsanonline View Post
    What did you end up doing then?
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Replaced with used carb, since owner wasn't very fond of Frankenstein's wild ideas!
    Would've loved to convert it into a fuel injected machine...
    brownrose78's Avatar
    Aug 2006
    1,594
    5
    10
    17 Post(s)
    u can go without issue
    Patriotism is when love of your own people comes first; nationalism, when hate for people other than your own comes first.
Tags for this Thread
