Results 1 to 13 of 13
Thread: Suzuki FX: Chamber Seal is leaking (Engine oil leakage)
    essanifaizan's Avatar
    Nov 2007
    33
    265
    2 Post(s)
    Default Suzuki FX: Chamber Seal is leaking (Engine oil leakage)
    Dear Experts
    Car is suzuki fx and oil is leaking from chamber seal from right side (Oil is dipping on Foundation and from foundation it drops on the floor).
    I show that to one mechanic and he is saying that for chamber seal they have to remove the engine completely but i would like to know is it possible to change seal by lifting the car up and do it?
    In case i have to take the engine out than taking this opportunity what other seals i should change or any other maintainance work can be done if really engine need to be out for changing chamber seal.
    Expert please advice what should i do?
    Sharo53's Avatar
    Nov 2009
    25
    2,414
    23 Post(s)
    In most of the cars seal can be replaced without removing the whole engine...don't know exactly about the Fx...
    but in case engine needs to be removed...check gear axle seals and thoroughly clean engine and engine bay...
    .........Tomorrow Never Comes Until Its Too Late........
    //////Life Without LOUD Sound System iz incomplete\\\\\\
    ceecix's Avatar
    Oct 2011
    26
    68
    Quote Originally Posted by essanifaizan View Post
    Dear Experts
    I have dealt with FX for a long time, as per my experience it can be done as bolts are downward facing, so yes chamber seal can be changed by slightly lifting the car, even lifting with a simple jack will do the job!!!!
    Performance is the never ending game with never ending charm!!!
    Nov 2007
    33
    265
    2 Post(s)
    Dear Ceecix & Sharo;
    I checked with one mechanic and he told me that for FX we need to remove the Engine because the GARDARI is below the engine. I checked my self and i can see the bolts facing dowards so at that time my personal opinion was it could be done with out removing the engine it self.
    I will again recheck with other mechanic and keeping the close eye on Oil levels
    As for removing the engine the mechanic is asking Rs. 2000 and for all the seals i have to purchase them seperately. but let me get 2nd opinion and take decision accordingly
    racer7's Avatar
    Oct 2012
    1,578
    5
    40 Post(s)
    7 Thread(s)
    Will you please post the pics for better understanding and comments.
    Nov 2007
    33
    265
    2 Post(s)
    See the attached pictures!
    MoizIrfan's Avatar
    Dec 2007
    Dubai
    26
    1,960
    106 Post(s)
    same case with baleno gadri has to be removed.
    its done with 3 jacks two lifting the car and one lifting the engine from gearbox side.
    then gadri is removed and then oil chamber.
    regards
    I was driving it by a kind of instinct, only I was in a different dimension...............................Ayrton Senna
    supraman2jz's Avatar
    Jun 2008
    33
    2,697
    76 Post(s)
    It's not a biggie. Get it fixed asap.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    worst case scenario you have to lift out the engine, this can be accomplished in less than 2 hours if working fast. While at it remove the welch plugs from the engine block and replace along with other parts like timing belt etc.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    oil chamber seal cannot be changed without lifting the engine out in FX
    https://www.facebook.com/OsamaAbbasPhotography
    Nov 2007
    33
    265
    2 Post(s)
    Quote Originally Posted by syncview View Post
    Thats true, i check with other mechanic he told me that it need to be lifted so what he check in details; so he change some seals at timing belt and did some thing with chamber seals. So besically now no leakage.
  12. #12
    daisyjohn's Avatar
    Nov 2013
    Check your oil.
    Use a fluorescent leak detection system.
    Apply a thin coating of talcum powder around the engine.
    Test the oil line
    Locate the oil pan gasket and remove any sediment.
    Look for multiple leaks
    Consider "steam cleaning" your engine to make it easier to spot oil leaks
  13. #13
    Sharo53's Avatar
    Nov 2009
    25
    2,414
    23 Post(s)
    @Xulfiqar
    sir what is welch plug and is its function....
