Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By joinami
Thread: Modified Carry Van
    qtanoli's Avatar
    Apr 2013
    Abbottabad
    25
    6
    Default Modified Carry Van
    Hi guys, I am swapping my f8b engine with 1kr-fe.
    Brought 1kr-fe complete with Ecu and Wiring.
    The overall plan is to mate the 1kr-fe to the carry van and use the standard (possibly shorted) tail shaft to get power to the rear wheels.
    I?m expecting that the engine wont fit under the front seats. Although it would be nice if I could make it work (don?t think the engine will like running on a 45 degree angle? Sump, pickup, intake?. etc) while retaining some ground clearance, I?m quite happy to cut up the floor pan behind the seats and mount the engine back there.
    Stock F8b Engine
    1kr-fe
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    why not try a k10 or k6
    haters gonna hate, potatoes gonna potate
    naveedm32's Avatar
    Sep 2012
    al-Ahmadi
    32
    470
    14 Post(s)
    subscribed.... I am also planning to swap my carby to efi in my low roof bolan. Will visit shuba bazar soon.
    DrUsmanNawaz's Avatar
    Jul 2011
    Wah cantt
    34
    3,939
    19
    165 Post(s)
    2 Thread(s)
    qtanoli's Avatar
    Apr 2013
    Abbottabad
    25
    6
    Recently i replaced my daewoo racer engine with toyota 4AFE engine,toyota engines r the best instead of Suzuki,In power,pick & Also in fuel consuption,therefore suzuki k10 engine makes alot of noise and also hav bad pick,fuel consuption is not so good for this vvt engine.
    qtanoli's Avatar
    Apr 2013
    Abbottabad
    25
    6
    Hi guys, Here comes Alot of problems in 1kr-fe,first its FWD and i make a plate to fit the Rwd gear box to yhe engine but on that position engine couldn't fit under the carry seats,
    Any suggestion ,which engine best fit to the carry ,above 1000cc engine must be efi.
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Not a good options though not impossible .
    Have to do lot of work on bell housing .
    If you have to swap
    Plenty of other options available .
    But swapping a Toyota in a Carry van is a tedious job due to very very limited available space .
    I remember I have swapped a Toyota 4K in my van ten years ago with original 4k transmission and differential .
    Than I put a G10 in it
    It's one of the best available option ever .
    Though I tried a K6 as well but 4 cylinder G10 is the best possible option .
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Quote Originally Posted by qtanoli View Post
    - Try to Stay Suzuki
    - go for G13 or G15 offered in APV or also in Jimmny .
    Easiest one is to get a 1.3 litre out of Suzuki every .
    -But stay ready for a brakes upgrade
    -Better bigger cooling system
    -improved front shocks
    - Gear shifter replacement .
    - and lots and lots more
    Old is Gold
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by joinami View Post
    [B]- go for G13A or G15A offered in APV or also in Jimmny . [\b]
    G13a and g15a both are carby engines op wants efi
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Both those engines available in EFI variants as well with different nomenclature . A-B
    Old is Gold
