Results 1 to 3 of 3
Thread: Alto lapin automatic gear oil`
    kazimriaz's Avatar
    Apr 2008
    32
    127
    Default Alto lapin automatic gear oil`
    I have Alto Lapin Automatic, i have to change Gear Oil can anyone tell me the name of gear oil for this car ?
    Every mechanic has its own story, kindly guide me.
    kazimriaz's Avatar
    Apr 2008
    32
    127
    alto lapin 2006 model.
    haroon959's Avatar
    Jul 2015
    Select City
    102
    As we all generally know that main function of the engine or gear oil is to keep the smooth flow of internal moving parts and reducing their internal friction as minimum as possible. Using low grade ATF or any other cheap oil may harm internal parts (like slow poison). But using Good Grade CVT Oil will make your engine more than Happy. Every day your car itself will open the door for you to sit & enjoy the good drive.... Zic ATF if pretty good and is usually recommended to users on this forum..... But please make sure you go for original ZIC transmission fluid... i heard they are also providing home delivery now.....But use Zic only if you can't find your owners manual for alto..... first priority is always the company recommended fluid mentioned in the manual.... you may look at the following threads for further info....
    https://www.pakwheels.com/forums/mechanical-electrical/155151-best-gear-oil-transmission-oil
    https://www.pakwheels.com/forums/mec...ansmission-oil
