Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: APV Gas Average on long with ac?
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    Default APV Gas Average on long with ac?
    Hello Xperts,
    I have APV 2005 Model and i used it on petrol for 3 years and now i have converted it in CNG with cylender of 75.
    I use APV only for long drives and it gives me 125km with AC each cylender (11kg gas each cylender) is it good average.? or how can i improve the average.?
    I look forward to have comments and tips of Xperts.
    Rgds,
    Teafi
    LIVE WITH YOUR PASSION
    kwaheed's Avatar
    Aug 2007
    46
    39
    125km in 11kg on highway is toooooooooooo low.
    Howmuch your car is doing on petrol?
    civic_2002's Avatar
    Aug 2008
    35
    120
    taefi jan
    yaar yeh apv ka cc to batao then u can calculate by formula youreself
    11 km mey 125 kg on highway ,means 11.5 km per kg of cng
    then tell do u use a/c but most important is capacity of engine in cc
    Warning: I am here to educate pupil, to create sense, to discuss logics, to give research, to increase literacy
    Beware!!! Dont come here for time passing or enjoyment,I will make you educated & mannered
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    Its 1500 CC,
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    Kwaheed how much it wud be ?i m worried about and think can save more money
    civic_2002's Avatar
    Aug 2008
    35
    120
    1500 cc hay to bura nahee hay because 1500 cc car itna to lay gee
    its in normal range
    acc. to formula: 1500 cc car can go to 11-12 km per kg with a/c
    ap ka avereage normal mey hay : 11.36 km /kg
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    OK, on my last visit to lahore it was 95km than i feel its bit low and went to CNG mechanic, he reduces the supply of gas to engine now its 125 but pick in first and 2nd gear is about u r on Khata reri..... How to handle with it .,
    can we chat in chat room if you don't mind Civic
    civic_2002's Avatar
    Aug 2008
    35
    120
    ok no problem for chat
    yes 95 is less but may be because of crowdy road,
    i think lesser gas supply make it khata reri on 1st gear,
    it is common mistake by mechanics,dont worry
    try to get in original flow
    then
    because if 1 time it gives u 95 then it doesnot mean that average decresaes,always check average by 3-4 readings
    for exapmle 1 trip u find 95 km
    2nd time refill full cylinder & check may be lets say 100
    3rd time refill giv 110 km
    then this means that it is not less average 95, there r many factors as
    crowdy road, ,weight in car, pressure of cng may be less at station from where u took cng etc.
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    I agree with you that avg is not same all the times, and agree too about your reasons about weight and rush on roads but i`m worried abiut the pick, yesterday i cam from lahore to sialkot and some times its hard to overtake the next car, i i went again to mechanic he will increse the supply of gas which will effect on avg.? so if i want to good avg than i have to bear the low pick problem .?
    :s
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    :s
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    I have Civic 2005 Prosmatec Exi and it gives me wonderfull pick and good avg, i have no problem of pic atleats and want same results for my APV
  12. #12
    LOR1's Avatar
    Dec 2007
    8
    164
    my 95 civic auto tranny (1500 cc) gave 110 Km with a 55liter cylinder on 90km/hr to 110km/hr at gt road with ac on and 4 people on board.
    How many passengers u were carrying?
    I guess apv is underpowered thats y u are getting low milage on gas.
  13. #13
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    i 'm carrying 8 passengers in apv and what do you mean by underpowered? can u explain it for me plz
  14. #14
    LOR1's Avatar
    Dec 2007
    8
    164
    was just thinking as this APV should be atleast 2000 cc coz i have seen apv with 10 people i think it is a bit underpowered. Coz cars are coming in with 1300, 1500 and 1600cc for 4 pesengers. U got a good average for 8 pessengers.
    The average i got 110Km froma 55 liter cylinder was of a 12 years old engine with aggressive foot on pedal so i was comparing it with yours but still i think it is ok.
  15. #15
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    what i think ?
  16. #16
    LOR1's Avatar
    Dec 2007
    8
    164
    on a 1500cc with 8 pessengers on board with 75 liter cylinder and also with weight of APV is higher then that of cars how can you expect to over take a car especially when you are running on CNG. That was why i was calling it underpowered as to weight to torque ratio.
  17. #17
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    LOR, by your words of underpower i admit yes its undpower and i feel its rpm is also higer than other vehicles, for example if i'm on 100 speed the rpm wud be at 3500, i think its also a reason to consume more CNG, what u think LOR
  18. #18
    LOR1's Avatar
    Dec 2007
    8
    164
    yeah that also can be reason, coz on your civic, on 100km per hr ure rpm would be around 2.5k to 3k max
  19. #19
    civic_2002's Avatar
    Aug 2008
    35
    120
    teafi bhai
    ap sirf proper cng tuning computerised wali karaiye, just 200-250 Rs.
    then pick prob will be resolved
  20. #20
    teafi99's Avatar
    Feb 2008
    Bradford
    42
    169
    Civic we have not got any computerised in our PIND Sialkot, suggest any good workshop if i want to fix it from lahore?8-|
