Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Like Tree1Likes
Thread: Toyota Estima Lucida Timing belt change
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Smile Toyota Estima Lucida Timing belt change
    Its been a year that we bought this minivan and were not sure if odometer is showing genuine mileage (problem with grey imports). To get peace of mind and be sure that it doesnt give up on me suddenly and hand over a heft overhaul bill. we opened it up for a timing belt change, which is a task in its own since the engine is mounted sideways under the front seats. It has turbo and an intercooler as well bringing in lot of piping going here and there.
    Started off by taking the seats out. Taking off the carpet and engine covers.
    Toyota Estima Lucida Timing belt change -98271 Toyota Estima Lucida Timing belt change -98272
    Keep a cool head and wear seatbelts!
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Engine top revealed
    I always wondered looking at the engine bay how one can adjust valve clearance on this thing and look around the internet to find a very good community of Estima Owners www.Estimaowners.com which is a UK based site having almost all info you need to maintain Estimas. There i found tutorials and threads explaining various maintenance procedures.
    We got to see the engine valve cover finally after 2 hours
    Toyota Estima Lucida Timing belt change -98273
    Check the intake pipings bring air in and out of turbo, then the intercooler and finally the engine.
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default EGR and Throttle plate
    Diesels do not require a throttle plate for normal working but EGR(Exhaust Gas Recirculation) makes it necessary to have a throttle plate on intake along with TPS (Throttle Position Sensor). It was a little gunky because of EGR so we blanked it from both ends, Exhaust and Intake.
    The side of throttle plate exposed to exhaust gases?
    Toyota Estima Lucida Timing belt change -98274
    Intake side was relatively clean
    Toyota Estima Lucida Timing belt change -98275
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Air Temperature sensor in intake manifold
    Toyota Estima Lucida Timing belt change -98276
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Timing cover off
    Finally the covers and belt were out after taking off the front shaft driving all the auxiliaries. This is an estima specific system due to placement of engine in middle.
    Toyota Estima Lucida Timing belt change -98277
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    It was not as bad as we expected it to be. Everything was clean and tidy. Piping, clippings, eletricals. Everything was in place neat and clean. Big relief after so much effort just to reach the timing belt
    Went to buy parts. We intended to change the following parts
    • Timing belt
    • Timing bearings
    • V belts
    • Front disc pads
    Timing belt was easily available, original from Toyota costed 2900. One of the timing bearings is again estima exclusive with a collar on sides to hold the belt in place. That one has to be ordered and delivery time was 7 days. So we had to out back the old ones which were not in a bad shape. I intend to open it up agian after 50k kms making al parts available before hand because of the bearings not being changed this time.
    V Belts were also a pain to find. But got them from a specialist belt vendor at Baboo Mohallah, Pindi.
    It was dark till the time we got back after parts purchase.
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Cleaning
    Chota did the washing part while we were away. A can of WD-40 was all it took along with some kerosene oil
    Toyota Estima Lucida Timing belt change -98283
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Putting in the new belt
    Timing Belt specs
    Toyota Estima Lucida Timing belt change -98284
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Toyota Estima Lucida Timing belt change -98286 Toyota Estima Lucida Timing belt change -98287
    khanrocks's Avatar
    May 2005
    Select City
    3,144
    42 Post(s)
    13 Thread(s)
    Great Going Boss ..
    "" PAKISTAN ZINDABAD ""
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    its nice to know that mechanics in PK can do a good job on imported cars..
    good work done..
  12. #12
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    After this i was too busy to take pictures. We did valve clearance adjustments, a coolant change, disc pads cahnge and V belt change.
    Next on list are cleaning the fins on condensor, radiator and intercooler. Have to take front bumper off for that.
    It is purring like a charm now after EGR blanking. Who cares about emissions anyway
  13. #13
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by iLLDuDe786 View Post
    good work done..
    It was a job well done and you have to be half mechanic yourself to maintain these beauties Being on pakwheels and participating in technical threads make you learn so much that a mechanic with bad intentions cannot dodge you into bad repairs.
    Thank God our mechanic is a very well trusted one and he knows what he do and how to do it. He doesnt mind taking advices from us and giving them as well, which makes it very comfortable to work along.
  14. #14
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by khanrocks View Post
    Great Going Boss ..
    Thank you boss
  15. 30-06-2010, 11:08 AM
    Senior PakWheeler
    Reason
    Non serious reply in professional forum
  16. 30-06-2010, 11:12 AM
    Senior PakWheeler
    Reason
    Another non professional reply :)
  17. #15
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    I love threads like this. Thank you for posting it here.
    A few suggestions:
    This is a good time to inspect all the seals at the front of the engine and the water pump too, since any leak will cause much more trouble if not stopped.
    On some models, a new timing belt tensioner is recommended with a new belt.
    If maintained and driven with care, Lucida/Estima/Previa models are very durable vehicles, and it looks like you will enjoy this one for a long time!
  18. #16
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    We checked the seals and water pump as well. They were fine. We hunted a lot for bearings but they were not readily available. Now we will open it up after 50k kms and will arrange all parts before hand. For now its doing good and bearings were also in a tidy condition.
  19. #17
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by spectra View Post
    That sounds great. After all, you plan is to open it again in about 30k miles, and that is just a short drive around the block for these engines.
  20. #18
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    a very nice and thorough job Saqib bhai. its always a pleasure to see a technical post made by you.
  21. #19
    hash4u's Avatar
    May 2005
    38
    24,377
    18
    404 Post(s)
    13 Thread(s)
    13
    where did u buy the engine parts from?
    has the avg improved
  22. #20
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    bohat allu ustaad!
    seriously it's so much fun watching your DIYs,.. and i'm sure having nashit around is a true blessing.
