Results 1 to 10 of 10
Thread: Mark X bonet cable
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    Default Mark X bonet cable
    my mark x bonet is not opening, i guess something wrong with the wire, may be its free, what to do, someone told me the denter will cut the front grill in order to fix it
    murtaza_murti's Avatar
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Quote Originally Posted by asadsethi View Post
    Your bonnet's cable might be either disconnected or damaged, or it has been unstuck from the release mechanism from inside the bonnet itself. If your repair guy can take out the front grill without cutting it that'll be the best way to gain access to the engine bay, if not then removing the bumper and fender would have to do.
    - '06 Toyota Belta 1.0L X - '68 VW Beetle 1300 DP - '89 Nissan B12 E16
    Site Banned Follow
    vyrus's Avatar
    Nov 2009
    25
    1,611
    Cutting the grill ? DAMN!
    nasir007's Avatar
    Sep 2007
    1,576
    6 Post(s)
    I think it can be fixed without cutting the grill !
    "Live Fast, Die Young and Leave a Beautiful CORPSE "
    How much horsepower gain do you get from your NOS sticker ?
    aizaz1992's Avatar
    Nov 2009
    24
    41
    brother ask your mechanic to remove the bumper...! if he cant do that fully ask him to remove the lower clams and tilt it slightly not to break the top bond and then work his way up to open the grill OR the bumper clams first and then the grill and do the fixxing ! HE DOESNT HAVE TO DO that... bumper thora sa lift kero (remove lower clips) and then remove the grill OR bumper top (which ever is easier or comes first!) and there you go
    exceed's Avatar
    Oct 2004
    london
    36
    287
    pull the bonnet lever as you would to open it and hold it in the pull postion ask someone to tap the bonnet where the catch is obviously that many times releases it if not pull and push the bonnet gently again using the same methord if that doesnt work then it could be broken or streched cable
    airomerix's Avatar
    Aug 2009
    26
    4,373
    5 Post(s)
    DONNOT cut the grill! It will cost you 12000!!!! Like aizaz1992 said remove the bumper and make its way to the grill. Your repair guy will deny it due to the ultra long procedure but still its your car.
    R18 boyz!.....Powered by Honda
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    lets c what happens, i am taking car to the denter now
    highalert's Avatar
    Jun 2008
    30
    194
    oo bhai ku gari barbad krwane pe tule howe ho denter to farig kr dega grill ko agar expert bnda na howa to ........... agar cable jam hai to pallas se khainch kr try kr lo inside se umeed hai ap ka masla hal ho jy ga ku k mere sath aesa ho chuka hai aik dfa ........ mere pass 2007 modal Mark X hai
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    problem solved, thanks all for ur support, my denter took hardly 10 mins, he went under the car, open the shield, then put his hand inside and opened it, the wire had some prob, now solved
