Page 2 of 13 FirstFirst 123412 ... LastLast
Results 21 to 40 of 252
Like Tree1Likes
Thread: Mark X servicing
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Mark X servicing
    Bought a 300G for my borther in law a week ago, black 2005 model, 2009 registered, 75k kms driven, in good nick
    As it is driven 75k kms alreadya nd we are not sure about service history so went through the following:
    Oil and oil filter change
    Transmission oil and Differential oil change
    Fuel Filter replacement
    Air Filter replacement
    Spart plugs replacement
    Cabin filter replacement
    Brake Fluid flush and replacement
    Brake servicing including new hand brake leathers
    General check ups
    Here is the car
    Mark X servicing -175577 Mark X servicing -175578 Mark X servicing -175579 Mark X servicing -175580
    Keep a cool head and wear seatbelts!
  2. #21
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by mics420 View Post
    I think you may also replace engine coolant and steering pump fluid.
    Very well pointed and good to see you here after a long time
    Coolant was fine, we just topped up the bottle with Toyota coolant, Power steering is Electronic so that is a saving of fluid cost
  3. #22
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by 2c View Post
    your brother in law is lucky to have you
  4. #23
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    The whole servicing has given confidence that the car is good to go for next 100,000 kms at least.
    Most of the work was getting done for the first time, including plugs, brakes, Tranny and Diff fluids so comfort level with the car is now excellent.
    It has a maintenance free timing chain instead of Timin belt so that is also a saving. Checked the V belt as well and it was fine, Will replace it at 100,000 Kms inshallah.
  5. #24
    waitnbl33d's Avatar
    Dec 2007
    32
    1,509
    8 Post(s)
    Quote Originally Posted by spectra View Post
    Mark X servicing - 175587
    a good writeup bro....this is whats needed whenever we buy a used car.
    just to clarify...the above picture shows the head ports.....not throttle bodies.
    "It ain't a motor unless its a rotor"
  6. #25
    waitnbl33d's Avatar
    Dec 2007
    32
    1,509
    8 Post(s)
    [QUOTE=spectra;2549821]Front (Air cleaner side)
    Mark X servicing - 175588 [img]
    this is the throttle body.
  7. #26
    jawafz's Avatar
    Apr 2005
    36
    175
    Please change the rims as well
    Keep smilling.
  8. #27
    autophile's Avatar
    Sep 2004
    13,578
    20
    6
    405 Post(s)
    Nicely done
    Be polite on the road. Always give way to others, particularly ambulances and pedestrians.
  9. #28
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    very informative, the stuff done and the cost.
  10. #29
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by waitnbl33d View Post
    YOu are absolutely right that these are head ports, but this engine has got individual throttle boides inside the head ports as well. look closely in the picture
  11. #30
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by jawafz View Post
    acha jee
  12. #31
    waitnbl33d's Avatar
    Dec 2007
    32
    1,509
    8 Post(s)
    hmmm you're right...those do look like individual throttle bodies !! din't look close enough !
  13. #32
    salik990's Avatar
    May 2006
    33
    4,260
    57 Post(s)
    @spectra: nicely done service....its gud for other markx owner to get idea...i ve markx too but its done only 31k....i ve change the oil filters n oil 2 weeks bak....which oil u r using n i wud recommend u to get synthetic oil n for Toyota ATF WS is suited for our 6 speed auto transmission...dont tell me u have put 4 litre engine oil coz it use 6.5litre, ATF oil u ve put only 1 liter?
    P.S get rid of tht rims...get original markx S-package rims
    My lugnuts require more torque than your Vtec can put out...
  14. #33
    salik990's Avatar
    May 2006
    33
    4,260
    57 Post(s)
    Specification
    Transmission Type A960E
    Engine Type 4GR-FSE
    1st 3.538
    2nd 2.060
    3rd 1.404
    Gear Ratio 4th 1.000
    5th 0.713
    6th 0.582
    Reverse 3.168
    Fluid Capacity Liters (US qts, Imp. qts) 7.2 (7.6, 6.3)
    Fluid Type TOYOTA Genuine ATF WS
    i ve copy pasted from site bout the transmission info n gear oil recommend by toyota...ur is 3GR-FSE markx but the transmission is almost same...
  15. #34
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by salik990 View Post
    Specification
    Engine Type 4GR-FSE
    1st 3.538
    2nd 2.060
    3rd 1.404
    5th 0.713
    6th 0.582
    Reverse 3.168
    You are absolutely right and i bought the oil accordingly but this is for a completely empty transmission when you open it up completely for a rebuild or some work inside.
    If you open the level nut and drain nut, around 4 liters come out and you put in the same
    @Ghuncha has some theory on it from the transmission data of A960, going by which maximum replacement can be 1liter for this tranny It is still a mystery for me.
  16. #35
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    ATF WS is recommended for this transmission, due to non availability, i had to put in ATF T-IV, car is fine so far Lets see what happens.
    Frr oil, i think putting in Toyota 5W-30 or 10W-30 is wise and change should be at 5000 kms
    I am trying to get rid of these rims mate, wish me luck
  17. #36
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Here is a usefull link for A960 Tranny causing confusion about oil quantity
    http://avtopedia.ru/akpp/a960eaut.pdf
  18. #37
    salik990's Avatar
    May 2006
    33
    4,260
    57 Post(s)
    @spectra: i ve exact file of this transmission where i copy paste...i get all the markx info from mark-x.com n some other website btw u got the genuine spark plugs in cheap price some ppl told me it cost above 2k each
  19. #38
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Toyota's WS trans oil is recommended for CVT trans, if ur car's trans is CVT so do'nt use ATF T4 or any other in it cause transmission demage.
    There's no car like Mercedes-Benz.
  20. #39
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    nice car and a thorough job done on it.
  21. #40
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    ITBs Saqib Bhai ? They're there to block one intake valve at low RPM / load to increase swirl and improve torque and combustion efficiency.
    Mashaallah it's a nice find!
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
