Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 252
Like Tree1Likes
Thread: Mark X servicing
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Default Mark X servicing
    Bought a 300G for my borther in law a week ago, black 2005 model, 2009 registered, 75k kms driven, in good nick
    As it is driven 75k kms alreadya nd we are not sure about service history so went through the following:
    Oil and oil filter change
    Transmission oil and Differential oil change
    Fuel Filter replacement
    Air Filter replacement
    Spart plugs replacement
    Cabin filter replacement
    Brake Fluid flush and replacement
    Brake servicing including new hand brake leathers
    General check ups
    Here is the car
    Mark X servicing -175577 Mark X servicing -175578 Mark X servicing -175579 Mark X servicing -175580
    Keep a cool head and wear seatbelts!
  2. #61
    AWK
    AWK is offline
    AWK's Avatar
    Oct 2009
    Dubai
    153
    4 Post(s)
    2 Thread(s)
    I am not sure but I guess I paid 3500 or something for 4 litre
    But check with toyota Islamabad
    Plus If interested PM me, I can guide you on how to turn off seat belt beep for pessanger side, or turining off traction 100%
    One more interesting fact is ...Put the key in driver door and unlock it and keep it there...it will unwind all the windows from outside and the other way would wind them all up
  3. #62
    mani1's Avatar
    Mar 2006
    30
    4,524
    mobil 1 for 3600? I checked from everywhere in lahore and the rate varies from 4500-4800!
  4. #63
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    Greatt car and excellent description on parts.
    How did the car drive after all this work? i am sure there wud have been a very decent difference in drive.
    Haha good option, but seriously no use ov it, even i rarely put down my windows.. too much dust and crap in our environment.
  5. #64
    salik990's Avatar
    May 2006
    33
    4,260
    57 Post(s)
    Quote Originally Posted by AWK View Post
    unless if u dont have smart key....most of them have smart key to wind window down n up by pressing smart key
    My lugnuts require more torque than your Vtec can put out...
  6. #65
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    @ Spectra
    Sir I own a Mark X as well and type 4 gear oil is not recommended for Mark X at all. The only oil you should use is WS. It is always available at Toyota Islamabad
    Infact I was reading at a forum and the use of type 4 can ruin your gearbox. I would recommend to immediatly flush your gearbox and get WS
    For differential always use liqui Moli
    Engine oil I personally use Mobil One only and change it after every 5000 KM
    Type WS is preferred for its superior lubricity and durability, but T-4 can work albeit with a shorter life and crisper shifts, providing it is changed frequently.
    Again, if WS is available, it should be used, no doubt.
    Quote Originally Posted by Ghuncha View Post
    but the oil filling quantity and emptying the tranny out is still a mystery
    Why?
    The majority of the fluid is in the torque converter and clutch packs, which are not drained when the pan is drained.
    Typical drain and refill on a Toyota auto trans is only a few quarts (liters) around 2 to 5, with the total capacities ranging from 7 to about 15 quarts (liters).
    The fluid level requires a certain temperature to be checked, but otherwise it a fairly straightforward procedure like the manual indicates.
    Some people use a machine hooked through the trans oil cooler pipes to change out all the fluid, while others have hooked up simple home made pipes and done the same if you are so inclined.
  7. #66
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by salik990 View Post
    Mine has a push start so that key is smart key? or something else?
  8. #67
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    Quote Originally Posted by spectra View Post
    Push start system means you have a smart key.
  9. #68
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by VCheng View Post
    Why?
    Million dollar question? SHould i drain all fluid (somehow) and change back to ATF WS or let the car run like it is running now?
  10. #69
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    The T-4 can be run for now with no problems in my opinion, but for peace of mind..... it's up to you.
  11. #70
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Very Nice topic. really useful info for all mark x users.
    In case of a engine more oil is more dangerous then less oil, i wonder how it goes for a gear box
    RIP
  12. #71
    sameer3389's Avatar
    Apr 2005
    Faisalabad
    33
    1,973
    34 Post(s)
    2 Thread(s)
    gr8 job saqib bhai car is also nice
  13. #72
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by qwertypoiu View Post
    Auto gearboxes need correct levels of fluid as well as the properties to work as designed.
  14. #73
    UJ_36's Avatar
    Dec 2009
    Sialkot
    26
    3,211
    8 Post(s)
    2 Thread(s)
    guddd
  15. #74
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    Why?
    its not about tIV the worries me but the fact that we might be running it above the max level, and a mixture of tIV and WS
    its all about power to weight ratio...
  16. #75
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    the manual says you can use TIV if WS aint available but should replace it to WS ASAP
  17. #76
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    I dont feel like risking t he tranny with lesser oil so it is the way it is for now. As thec ar was running fine previously and now as well so i guess extra oil (if any) is just roaming around inside
    Also, post next steps of ATF filling, there are around 20 of them
    vcheng i was talking about this, yes it is that oil level should be on the recommended level but isnt more oil more dangerous then less oil
    RIP
  18. #77
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Overfilling would be bad with excessive clutch pressures and seal blowouts a risk.
    The mix is no problem IMO.
  19. #78
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    You are correct: More oil is dangerous here too.
  20. #79
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    can anyone confirm how accurate level is to be ensured. we did it the old fashion way by opening the upper nut and when oil came out of it, we stopped filling it.
  21. #80
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    The procedure needs to be followed exactly with the right temperature a must.
    That is the best way for the correct oil level.
    I have a 2006 IS250/350 service manual and I think your car has the same trans and procedure. I will read up on it and check at my end.
