Page 6 of 13 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 252
Like Tree1Likes
Thread: Mark X servicing
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Default Mark X servicing
    Bought a 300G for my borther in law a week ago, black 2005 model, 2009 registered, 75k kms driven, in good nick
    As it is driven 75k kms alreadya nd we are not sure about service history so went through the following:
    Oil and oil filter change
    Transmission oil and Differential oil change
    Fuel Filter replacement
    Air Filter replacement
    Spart plugs replacement
    Cabin filter replacement
    Brake Fluid flush and replacement
    Brake servicing including new hand brake leathers
    General check ups
    Here is the car
    Mark X servicing -175577 Mark X servicing -175578 Mark X servicing -175579 Mark X servicing -175580
    Keep a cool head and wear seatbelts!
  2. #101
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    you did put in a new filter right? and how come the pan has no magnets in it. It should have atleast one. Helps a lot.
    about draining everything - you can use the oil cooler lines to flush the transmission completely. thats why I love the mercedes design - they have a drain on their torque convertor - open it up and you have more fluid in it than you had drained from the pan.
    Filter is new. I was away while they did that. Pan had 3 magnets, not present at time of taking oicture though.
    About Oil cooler, this car has a small contraption (like oil coolers on toyota and nissan diesels) bolted to transmission for this purpose, lines for water reach the transmission rather then oil getting circulated through lower radiator tank. Opening the whole thing for oil drain was not advised by toyota people.
  3. #102
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by nomicool View Post
    Good thread...can you guide me on the diff oil? When to change it? Recommended oil?
    GL-5 synthetic is recommended.
  4. #103
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by asadsethi View Post
    @ spectra
    i need ur cell no. I have recently bought mark x 3g Premium, just changed its mobiloil, oil filter, coolant and air filter, need to change other things/ oils also, although milleage on odo says 40k but not sure, they can b easily reversed. So i need ur cell no for some discussion
    Replying you on your email.
  5. #104
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by spectra View Post
    good, but its pretty easy to dismount the fluid lines and flush fluid from there, It requires some "other" tools which they must not be having at that time.
  6. #105
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    I beleive they went shy of the transmission temperature sensor installation at same place within that cooling unit.
  7. #106
    HotEngine's Avatar
    Apr 2007
    Balakot
    25
    5,747
    3 Post(s)
    nice black beauty
    https://www.facebook.com/EbdullahPhotography
  8. #107
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    @spectra
    thanks for talking on phone, pl update what happened to headlight of mark x
  9. #108
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    headlight needs a new bulb.
  10. #109
    incognito59's Avatar
    Sep 2006
    57
    3,174
    41 Post(s)
    16 Thread(s)
    Have a question to ask? The other day I took my 2.0D for 40k service to Toyota among other things I also got the Power Steering Fluid changed. The Toyota guys used ATF to replace it. I asked them including the supervisor and the answer I got was not to worry they used same ATF for PS too in all cars. Can any expert comment please?
    life is but wheels!
  11. #110
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by incognito59 View Post
    It is normal, Power Steering oil and ATF is same. Some exceptions can be found but not in Paksitan.
  12. #111
    Sep 2006
    57
    3,174
    41 Post(s)
    16 Thread(s)
    Thank you brother.
    life is but wheels!
  13. #112
    VCheng's Avatar
    May 2010
    Select City
    25,475
    7
    434 Post(s)
    4 Thread(s)
    That oil and pan look CLEAN. The service probably was not needed at this time, but I think that you did the right thing for peace of mind and long trouble free service life.
  14. #113
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    so have u chnaged the bulb, pl let me know where from and at what price, regards
  15. #114
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    It says to use ATF on the reservoir too - for peace of mind you can also check the bottle they pour from.
    And in nearly all cars PSF is ATF unless its some heavy duty application
  16. #115
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Havent checked about the Projector lamp yet. Will visit market on saturday.
  17. #116
    ashan646's Avatar
    Jun 2007
    New York
    31
    355
    how much did u buy it for?
  18. #117
    Sep 2006
    57
    3,174
    41 Post(s)
    16 Thread(s)
    Thanks a lot. My mind is at ease now
    life is but wheels!
  19. #118
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by ashan646 View Post
    3.4 Million Rupees for the car and the maintenance spend totalled 65k
  20. #119
    skylinegtrr34's Avatar
    Nov 2004
    28
    854
    Quote Originally Posted by 2c View Post
    your brother in law is lucky to have you
    agreed +1!! lol
    MASHALLAH nice ride man
    R.I.P BABRUS ABBAS QAISER....will miss u bro....i got a memories but not u....
  21. #120
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    @spectra
    yesterday i went to hamza younas autos , pindi saddar , regarding lamp changing, it hardly took a minute to change the HID lamp, cost 7500, but then it was far brighter than the other side lamp, so had to change the other one also, so in total 15000 for two lamps, they were also emphasizing to change headlight glass cover as it would change the car look to new, but i had limited time, will do it next time, cost around 16000 for pair, not exactly remembered, then i changed the front grill, as the old one was slightly broken, the new one is grey chrome, cost 11,500. Also changed spark plugs, each cost 1950, then changed cabin filter cost 3300. Hand break leather also bought, two pair cost 4000. In total i paid 45000, few things also to be changed but on next visit, hopefully to cost another 45000. But i guess these r one time expenses and then confidence on ur car for next 75000 kms. Thanks spectra for ur guidence.
