Results 1 to 7 of 7
Thread: any good mechanic for mark x in lahore/rwp
    iftikharraheel's Avatar
    Nov 2007
    Select City
    46
    155
    Default any good mechanic for mark x in lahore/rwp
    My mark x 2006 engine check light is on because of oxygen sensor problem.I want to replace the sensor and also require a thorough check up at 50,000 km.new oxygen sensor is available at faisal autos montg road lahore for 10,500/.I ll also check hamza younas autos rwp saddar tomorror for the availability of o2 sensor.I reside in gujrat,so lahore or rwp are at the same distance from me.
    mani1's Avatar
    Mar 2006
    30
    4,524
    I don't know any mechanic for mark x but you can try toyota dealerships. Plus have you tried resetting the O2 sensor? I believe it can not be done from OBD and has to be done some other way. It may solve your problem
    sohna's Avatar
    May 2011
    Select City
    688
    2 Post(s)
    Hi The problem is going to start right now.............
    What an Idea SIR G.......
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    Quote Originally Posted by mani1 View Post
    how do you reset a sensor
    you can reset the ecu, but not a sensor, if o2 is faulty it needs replacement.
    10500 is not a bad price at all in my opinion, just verify the part number.
    its all about power to weight ratio...
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    sensors usely have long life. do verify if sensor is out of order before buying another. maybe a wire is broken.
    engines run ok if O2 sensor is missing from circuit, chk light should not come "on"
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    IN a Mark X O2 sensor will through a code definately. But how are you sure that it is the O2 sensor? Also i think there are 2 O2's in mark X. Better be sure or you might have to change both.
    Keep a cool head and wear seatbelts!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    on every reset the ECU needs a driving cycle to go into drive mode. and do verify what the code was? O2 sensor lean/rich codes are set due to an air leak in the manifold or incorrect fuel rail pressure too.
