Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By raging_ravin
  • 1 Post By Xulfiqar
Thread: Premio ATF
    nasty_faizan's Avatar
    Mar 2008
    26
    190
    Default Premio ATF
    While driving my premio '05, I can feel the gear change taking longer than usual...like more revs before gear change. Please tell me how I can check if oil needs to be changed. And if it needs to be changed, where should I get it done from in karachi? Thanks.
    "Mian, mainey to tumharay abba ko bhi theek kia hai...."- Baba Hassan.
    raging_ravin's Avatar
    Jul 2011
    28
    669
    2 Post(s)
    First of all mention the mileage of the car. Also mention if the transmission oil has been changed before, if yes, when ?
    Shifting taking longer than usual can be caused by many things, i guess some sensor stuff may be. The experts will guide better.
    Post the answers to the above questions so that the experts are able to guide you specifically.
    Honda, Sony, AMD, Android, Grassroots, Hiwatt, Turtle, Dream Theater !
    Mar 2008
    26
    190
    Quote Originally Posted by raging_ravin View Post
    The odo tells 30k, but its impossible to know exact since the meter was probably reversed by the dealer. When we bought it, it showed 8k. And ATF hasnt been changed by me before.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Change it on FIRST priority, find out what spec fluid your transmission needs and do it.
    Jul 2011
    28
    669
    2 Post(s)
    Quote Originally Posted by nasty_faizan View Post
    it is best to get the automatic transmission oil changed. your car probably uses dexron VI, but since toyota's own fluids are available, it would be better to get toyota ATF.
    whether this solves the problem or not, you should get the transmission oil changed. in fact, it is recommend getting all the fluids changed and all the belts and connections checked when a used car is bought.
    You can find Toyota ATF almost anywhere in karachi, but you'd prefer going to tibet center/rimpa plaza if you want the best price (trust me the difference is there)
    For getting it changed, you can do it yourself if you want, it is very easy. if not, almost any mechanic can do it, visit the one you trust.
    and yes, do update !
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    Most probably it would require Toyota T-IV fluid. Its different from the WS (world standard) fluid and GM Dexron 6 fluid.
    Remember to install a new filter too - it would be a paper type.
    6Forward's Avatar
    Feb 2012
    203
    Change the transmission fluid and use ZIC XP III
    Jul 2011
    28
    669
    2 Post(s)
    can't the GM Dexron VI be used ? as i somehow understood that toyota fluid is based on GM dexron ? just asking.
    Mar 2008
    26
    190
    False alarm guys. The more experienced drivers who drove the car tell me that its fine and woh sirf mera 'veham' tha Anyways, if I have to get it changed in the future, where should I get it done from in Karachi? Last time I got the atf changed for my previous car (vitz) from toyota defence and feel like they are a total rip off..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by 6Forward View Post
    That is a recipe for disaster on this car's transmission
    Toyota T-IV is this fluid
    Mobil ATF 3309 Automatic Transmission Fluid
    GM dexron 6 is not 3309
    Jul 2011
    28
    669
    2 Post(s)
    Brother, i dont want to sound confusing, but it is not a matter of 'experience of driving' all the time. some times it is the 'experience of a particular car' as well. if you were driving the car before and you are driving the car now, you know the problems of the car and how it behaves more than anyone.
    As i mentioned before, go to any good mechanic you trust, changing ATF is a pretty simple job. this is what xulfiqar bhai had to advice me:
    Flushing the trans is easy, drain and fill with the quantity removed, remove the cooler pipe that moves fluid to the radiator and put in a pan, start engine and add oil till the the oil coming from the cooler looks newish, usually the whole transmission holds about 7.5 litres so about 8 litres is enough.
  12. #12
    Jul 2011
    28
    669
    2 Post(s)
    ZIC XP III is formulated for hyundai, kia and mitsubishi automobiles.
    If the OP wants to go for ZIC rather than toyota fluid, he can choose ZIC ATF III.
    helpful, as always.
  13. #13
    AZEEMMAJEED's Avatar
    Jan 2009
    22
    3,313
    43 Post(s)
    3 Thread(s)
    also clean the oil chamber of transmision also
