Results 1 to 4 of 4
Thread: Probox engine shakes heavily when i accelerate on Idle?
    polepar's Avatar
    Jan 2010
    Peshawar
    31
    99
    Default Probox engine shakes heavily when i accelerate on Idle?
    Recently purchased a probox, everything is fine, however When I push the accelerator hard on "Parking/neutral" then the engine starts shaking heavily...is this normal for Auto engine or something wrong?
    please let me know soon so that i shud check it by mechanic then.
    everything else seems fine, excellent pick and speed etc, however the gear shifting is little bit jerky sometime, although i have changed the transmission fuel.
    zxmco125's Avatar
    Feb 2005
    Faisalabad
    28
    4,929
    23 Post(s)
    AOA. Mabrook on your new purchase. Drive safe.
    As you describe the matter you facing. It seems me that its engine foundation is broken. Kindly check and replace that. Then the thing will be fine.
    Defeat is not when you start to losing the race.....it is when you refuse to Accelerate!
    Lyallpur Auto Detailing | http://www.facebook.com/lyallpurautodetailing
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    there are 4 foundations all in & under engine bay front behind the radiator & near the steering rack is rear 1 - 1 at right next to shock mount bulge 1 at under the left wheel bulge. Check all 4 most likely the rear one over the rack / transmission side one bad - replace set of 2 not just one.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    This may be happening because of following reasons,
    1. Clogged air filter.
    2. Fuel starvation or over fueling.
    3. Incorrect ignition timing.
    4. Bad spark plug / Ignition system.
    Get it checked accordingly.
    Never loose hope in life,every step gives u something.
