Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By qwertypoiu
  • 1 Post By fawadakbarkhan
Thread: Toyota Camry (Headlight) problem
    doubletrouble's Avatar
    Mar 2005
    27
    1,574
    Default Toyota Camry (Headlight) problem
    Hello guys
    i have Camry 2008 ...
    The problem encountered is that the "LOW BEAM" of "Right Side Headlight" just went out.
    From where can i get the bulb which i suppose is HID but its not the one commonly sold it market..as far as i assume
    i went to Toyota and they are charging Rs. 36000 when i asked them last time...so is there any other alternative
    Would like PROFESSIONALS help on this one and URGENT as i cant drive in evening
    drug-s3x-money .....be careful: this is the kind of obsession that can render you utterly useless
    sardarsaeed's Avatar
    Jul 2008
    Toronto
    26
    693
    4 Post(s)
    First check if its the bulb or the ballast that is not working...
    SS..
    14' Honda Accord Sport..
    Jul 2008
    Toronto
    26
    693
    4 Post(s)
    Original denso ballasts (which come is toyota's, honda's, lexus etc) cost around $165 a pair...
    Original D2S Philips and Osram bulbs cost around $100 a pair and D1S bulbs cost around $170 a pair...
    You can get local Chinese bulb and ballast for your car, they were easily available last time i checked, but they wont be as good as the originals...
    SS..
    Mar 2005
    27
    1,574
    ^ il confirm tomorrow
    bro this is the point..not satisfied with chinese ....i might order from abroad but 1st i need to get to know the issue
    and the reason why they are so expensive here
    Jul 2008
    Toronto
    26
    693
    4 Post(s)
    The dealerships always sell parts at a much higher price.. Even if you get them from any dealership abroad, they are still going to charge you around $400 for just the ballasts..
    Check this site out : The Retrofit Source online: headlight upgrades for all applications ..
    One of the most reliable source for oem bulbs, ballasts, projectors etc...
    Im using the retrofit source's Morimoto kit's in my car's for almost two years now. never had any problem, plus their focus is excellent unlike the chinese bulbs...
    SS..
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Do note if you have to change the ballasts you will have to check it for both the head lamps as the new one will be brighter then the old.
    RIP
    fawadakbarkhan's Avatar
    Oct 2011
    100
    6,218
    143 Post(s)
    52 Thread(s)
    Bro, buying from toyota will cost you a fortune. Their profit percentage is over 250% on spare parts. They charge like 26k rs only for a power windows motor of LC prado. try searching in kabli market, you'll most probably find a perfect replacement part, but first, as a bro said, diagnose the problem. Whether its with the ballast or the HID tube itself. According to the best of my knowledge, camry has 6000K HIDs as stock headlight.
    Agar chy bu'tt' hain Jama'at ki Aasteenon main - Mujhay Hai Hukm-e-Aazaan LA ILA HA ILL ALLAH...!
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    4300k is oem HID light
    RIP
    Oct 2011
    100
    6,218
    143 Post(s)
    52 Thread(s)
    ^^We once bought a 2005 camry, I think they were changed in it then. It had 6000K.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,596
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Exclamation
    Quote Originally Posted by RollOnBigMaMa View Post
    Quote Originally Posted by qwertypoiu View Post
    seems both of you have lost track of zeros for a K while mentioning K at end of figure - a K is 1000(3 zeros at right side of digit)
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Oct 2011
    100
    6,218
    143 Post(s)
    52 Thread(s)
    Quote Originally Posted by capsat View Post
    frankly speaking uncle, I didn't expect this from an educated guy of your age, this K denotes the "kelvin" scale of temperature and not zeros. Correct yourself.
    We are talking about High Intensity Discharge (HID) temperatures here.
  12. #12
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,596
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Thank you Bhanjay learned something about HIDs
    means that in Toyota Prado ( Petrol) the head lights are with HIDs ?? Because at low beam light is perfectly fine & enough for night driving but as soon as punch to high beam its kind of daylight (150 times more whiter & brighter then low beam)
    i do not see any blast box or any extra hard wire to the light in engine bay. & there is no flick or load on alternator or battery either
  13. #13
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Prado has Hid's/projectors in the latest model 120series has simple h4 bulb
    RIP
  14. #14
    Oct 2011
    100
    6,218
    143 Post(s)
    52 Thread(s)
    any time uncle jee.
    Yes, new prado has HID projector lights, but not the older one. But the older prado has lights anyways.
  15. #15
    waqar_zaffar's Avatar
    Jul 2005
    Multan
    28
    101
    2008 camry has E4 philips lamp by Default and yes it is lamp problem not blaster problem as i faced same situation few days ago, Toyota dealership gave me rate of 27000 rupees for single lamp but i bought Qabli one in 3200 rupees although iit was hard to find here. BTW @poster i have an extra camry 2008 genuine (Qabli) blaster with me if u need that then PM me.
