Results 1 to 12 of 12
Thread: Toyota Crown G Model 2000 check light on
    danish753's Avatar
    Mar 2009
    41
    79
    Default Toyota Crown G Model 2000 check light on
    hello guys ! i have a problem with my Toyota royal salon G Model 2000 check light. it goes on any time without any prob.what i studied is that my car fuel overs sometimes and than light goes on and it started missing,some time with a long self starting.anyone help me?????? sunny753@hotmail.com or 03004000666.
    SER_GTR's Avatar
    Nov 2005
    30
    9,736
    16
    489 Post(s)
    19 Thread(s)
    Retrieve Error Codes...Must Be Bad/Malfunctioning Sensor Or Ignition
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    Site Banned Follow
    engineermali's Avatar
    Jul 2009
    Quetta
    35
    7,883
    113 Post(s)
    25 Thread(s)
    Get it checked from toyota workshop.
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    on board diagnostic 1 - have chk light blinks diagonosed by direct e1 t1
    obd2 , fix adaptor - good electrians have it - probably its a sensor error in engine
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    danish753's Avatar
    Mar 2009
    41
    79
    when attach with computer it always give code (fuel too rich bank 1.fuel too rich bank2.and i hv changed oxygen both sencers but prob still there.checked all other sencers all working perfactly,changed main computer also but prob still there.main prob is what i think is the fuel is over sometimes without any reason and when i try to start my engine it take long self and starts with black smoke behind.this is the main fault.and by the way toyota ppl don knw anything abt crown i spent 6 months with them for this prob bro!!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    check the fuel pressure and leakage of injectors - leaky injectors will cause the engine to belch black smoke, rich O2 reading in otherwise normal engine is bad O2 sensor, when you say change do you mean "NEW" or used from scrap yard?
    danish753's Avatar
    Mar 2009
    41
    79
    replaced brand new sensors and checked injectors also they r fine no leakage bro.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    try hi octane petrol
    do u rarely use ur car ? petrol
    cng installed?
    coz if u rarely drive ur car and ur tank is filled with petrol.petrol get expired i have experienced the same
    danish753's Avatar
    Mar 2009
    41
    79
    ya 40% hi octane and 60% petrol always.but ya i rarely use this car and tank is always like full.no cng ever installed
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    by your postings - either your ECU is duff or your workshop is not inspecting correctly, If you have good injectors, correct duty cycle at the injectors, correct throttle opening, the ECU is not in "limp" mode, O2 sensors giving feedback and the engine has mechanically good compression and timing your engine should work correct.
    There is something missing from the equation here. It maybe that the O2 sensors wiring is shorted somewhere.
    danish753's Avatar
    Mar 2009
    41
    79
    ok will check sensor wiring than let you know bro.and mind this that i hv checked this issue from 4 or 5 different workshops of lhr and isb and obviously known workshops but nobody diagnosed this prob till now coz every thing shows perfact in scanner and phiscaly checkup .
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    if you say that you get error codes for O2 on scanner then it can be either the sensor or its wiring. The scanner does not tell you if its wiring or the sensor itself.
    To solve such issues - you have to resort to breaking it down to simpler bits.
