Results 1 to 11 of 11
Thread: Axio Fielder Average
    pathan101's Avatar
    Jul 2009
    Kohat
    31
    13
    Default Axio Fielder Average
    Salam,
    I have 07 model axio fielder its G edition 1500cc, well I purchased it about 1 month ago.
    The issue is on meter its showing average as 13.3, can anybody confirm whether this calculation of average is considerable?
    Also worth to mention I do drive car within city a lot.when I purchased the car the average was around 13.6 and now its around 13.3. I drive it with extremely soft pedal.
    Please suggest what to do, should I go for its tuning or what to do?
    -With Regards.
    Khurram26's Avatar
    Dec 2006
    38
    275
    13 Post(s)
    Quote Originally Posted by pathan101 View Post
    Salam,
    -With Regards.
    What you see is the historic fuel consumption of your car, being updated by the car computer since it was last reset to 0.
    In simple words, when you press the left button on your speedometer, it changes the display between outside temp, current km/l consumption, Average( this is probably what you have seen in your car), driving range, average speed and elapsed time.
    Talking about AVG , if you fill up your tank and you are in AVG mode, keeping the left button of the speedo pressed will reset the AVG to Zero. Now the car will calculate your fuel average for the whole tank, or till the time that you again reset it to zero.
    For example, if you fill the car up and set the AVG to zero, you can see the average for the entire tank when its due for next fill-up. But during this trip the AVG will keep changing gradually, depending on your driving style. In the beginning it is easy to achieve average of 18-20 km/l, since the car calculates the average for the amount of fuel consumed, which is less in the beginning but as you consume more litres, the kilometers travelled per litre reach a more steady and dependable figure.
    The car computer is very reliable. I have an Axio which gives around 14.5 km/l in Islamabad city driving. The average calculator works spot-on, every single time..
    pathan101's Avatar
    Jul 2009
    Kohat
    31
    13
    Nice elaboration, I really appreciate. I just reset the AVG to Zero as I have filled the tank. Lets see how the average is calculated this time.
    Well can you please explain the E/T as its shown in the left side, I can't understand what it means.
    Also is there any type of tuning required to further improve the AVG?
    Thanks once again
    mubeenshahid's Avatar
    Mar 2010
    Sargodha
    25
    8,355
    31 Post(s)
    2 Thread(s)
    Thanks once again
    E.t i think refers to car engine start duration.you can also reset that
    Sent from my Galaxy S2
    Aunda Fan
    pathan101's Avatar
    Jul 2009
    Kohat
    31
    13
    Well I have drive around 100kms after resetting the AVG meter to zero and now its showing 12.8 Km/L
    pathan101's Avatar
    Jul 2009
    Kohat
    31
    13
    Sir g my car is giving an average of 12.8 I mean i drive the car almost 200km around 120km in local and 80 on high way, I use very soft pedal i mean RMP is always under 2 but yet the consumption is high. I have 2007 axio fielder.
    Please advice what to do also i m using caltex 5w 40 fully synthetic mobil oil
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    have u done engine tuning?n did u get al fluids changed after u bought the car?
    www.facebook.com/performancepartslahore
    aqs29's Avatar
    Mar 2006
    Hyderabad
    3,129
    16 Post(s)
    Avg of 13kpl is about normal for Fielder
    aviator_12's Avatar
    Nov 2006
    41
    590
    Might b a 4WD version
    pathan101's Avatar
    Jul 2009
    Kohat
    31
    13
    Quote Originally Posted by aviator_12 View Post
    its 2 wheel not 4 wheel drive.
    pathan101's Avatar
    Jul 2009
    Kohat
    31
    13
    Quote Originally Posted by jz View Post
    Which fluid you are talking about please explain, also what type of tuning is needed.
