Results 1 to 17 of 17
Like Tree10Likes
  • 1 Post By Xulfiqar
  • 1 Post By meh1
  • 4 Post By Xulfiqar
  • 1 Post By Sharabhi
  • 2 Post By Xulfiqar
  • 1 Post By hsnmz
Thread: Prius owners rejoice
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    Default Prius owners rejoice
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    This car is not for us. firstly no official support from manufacturer. and then sky high prices of parts . if some parts are messed it would be better to throw old one in river and buy a new one . i think there will be time hybrid cars will be practical in Pakistan and this will be after a decade.
    hasooboy's Avatar
    Feb 2010
    29
    5,401
    81 Post(s)
    3 Thread(s)
    3000$ just for master cylinder :-\
    Sent from my HTC One S using PakWheels Forums mobile app
    Boy Badnam hua LIANA tery liya
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    hybrid cars are practical... its just that they need to have simpler parts...
    the problem is not our govt... its the people..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    ^^ like a horse and a tether.
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    lol....
    well for the illiterate owners and mechanics of cars in pakistan... i believe that is the solution...
    on the other hand... toyota could have used a normal master cylinder with a separate abs pump... like in their other cars.. i have seen jdm alto and kei and local swift... master cylinder is simple hydraulic cylinder.. and abs pump is separate.. at least if the pump stops working the normal hydraulic brake should work...
    design should have been robust.. mantain functionality even in case of partial failure...
    also modular designs are cheaper to make and replace. too complex parts are difficult to make.. easy to manufacture defects..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    ^^ the Prius cannot use a normal M/C as there is no vacuum assist whilst the engine is off, So they have to use a motor to function, Then it also is tied into the drivetrain as the car has regenerative braking, meaning that when you press the brakes gently the brakes dont work fully but the transmission applies a brake in itself through the MG2.
    This also means that the system keeps up with moving the pads onto the discs at all times, which also means that if you remove the pads without disarming the brake system - the pads can eject, more cluster fudge. This system is also employed by MB in some of their cars and is very very pricey to repair but it carries a 10 year warranty.
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    oh yeah... i forgot the engine is of at slow speeds...
    Sharabhi's Avatar
    Dec 2007
    29
    2,427
    5
    205 Post(s)
    6 Thread(s)
    sir like nfssaad said it totally depend on owner and our mechanics, i gave you my experience. I sold prius to Lahore genuine 62,000km driven car everything was working fine but after few days owner calls me and tell me that prius is not converting to Hybrid mode and he also get scan from so called toyota authorized service centres, they say battery fault and gave him estimate of 1,25,000/- with replacement of battery.
    But i have ask and discuss this issue with my friend who is expert in prius electronics and also Pakwheeler @capsat Sir. I told them the same thing, so eventually problem came that fault code HV is coming because. due to moisture the cable which discharge the battery to generator is faulty because it was winter season. So they change the orange type cable which are coming from hybrid battery to generator and problem solved. Cost of cable was Rs 10,000/- that too because in Lahore and Karachi we have many half cuts and spare of prius.
    My Cell: 0320-2197670 email: rasheedsahab2012@gmail.com
    Join my group if u love JDM cars : www.facebook.com/JDM.imports.Pakistan
    xenerking's Avatar
    Nov 2009
    36
    1,028
    16 Post(s)
    thank God for giving us Bilal Gunj
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by Sharabhi View Post
    not everyone has a expert friend
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    If you make ONE mistake while working on the orange cables - you become burnt meat, you die and you will reek of a smell that is more like burning a dead dog. Just for kicks if you know an a high voltage technician hand them a hot dog frankfurter and ask them to place it between a 600V short.
    The smell is beyond nasty.
    anyway - I just recently shipped a unit to Pakistan (MG2) i.e.
  13. #13
    CarSaaz's Avatar
    Apr 2008
    40
    1,648
    16 Post(s)
    Quote Originally Posted by xenerking View Post
    can you get good parts for cars like
    1-86 88 charade ,corolla and starlet?
    rgd
    "A government that robs Peter to pay Paul can always depend on the support of Paul. "If at first you don't succeed, failure may be your style."
  14. #14
    xenerking's Avatar
    Nov 2009
    36
    1,028
    16 Post(s)
    Quote Originally Posted by CarSaaz View Post
    rgd
    well if you know the name of part in generic language (USTAADI language) then there is good chance that the required part can be arranged, if you goto right shop and ask for required part, i have never seen the shop keeper astonished by the demand, however they try to hipe up the price by pretending that required part is very rare and hard to find in whole wide world...
  15. #15
    VCheng's Avatar
    May 2010
    Select City
    25,478
    7
    434 Post(s)
    4 Thread(s)
    Toyota covered him 50% for the repair out of warranty.
  16. #16
    WAkkY's Avatar
    Apr 2012
    273
    6 Post(s)
    Found this in the same post , Recall by toyota, im not sure of the Authenticity (Copy / Paste from web)
    New GenIII brake recall affects 87,000 cars | PriusChat
  17. #17
    hsnmz's Avatar
    May 2006
    2,192
    9 Post(s)
    a machine can malfunction at any time but JDM Prius are free from this problem. Also wrt the thread referred above for 3000$ repair the owner should have googled a bit. have a look at following links and you will know that this part is available at much cheaper price i.e. 250$-295$. let's say that replacing the part would cost 200$ (which IMO is a ridiculously high price). so the total expense would be 450-495$. Although the part is a used one in below links but I am pretty sure that these would have worked well for the owner.
    10 11 Toyota Prius Brake Master Cylinder with ABS Module Anti Lock VSC | eBay
    2010 Toyota Prius Brake Master Cylinder 36831 Miles 2394524 | eBay
    Pakistan Zindabad
