Results 1 to 10 of 10
Like Tree6Likes
  • 2 Post By iffe
  • 4 Post By Xulfiqar
Thread: Toyota premio problem after first oil change
    Umairaziz786's Avatar
    Oct 2008
    Abbotabad
    29
    166
    Default Toyota premio problem after first oil change
    Salam.i bought fresh import toyota premio 2007 1.8xex with japanese oil in it .after driving 1000km i changed the engine oil and inserted zic A+ 5-20...according to its manual ..but after changing the oil the sound of the engine is increased specially when accelerated quickly.previously it was very smooth and quite.plz tell what eng oil should i insert now.????thanks
    iffe's Avatar
    Feb 2004
    34
    1,031
    8 Post(s)
    Oil can be fake....
    Sent from my SAMSUNG-SGH-I727 using PW Forums mobile app
    He who hesitates is not only lost but miles away from the next exit
    Durrani_45's Avatar
    Mar 2012
    20
    5,244
    142 Post(s)
    11 Thread(s)
    japnese cars damn
    Sent from my GT-I9100 using Tapatalk 2
    miles to go
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    if its excessively noisy on proper grade of oil then the used car dealer who sold you the car probably poured something "special" to hide the noise
    zebmirza's Avatar
    Jun 2007
    Gujranwala
    28
    397
    go for toyota motor oil. not the petron ones but the imported one avialable at toyota motors in tin packing with grades i guess 10-30 the petron one is 20-50. i recommed the imported one. hopefully the problem will be gone.
    and yes get it changed by toyota they better know about that sound as well...
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    use 10W 40 as 5W 20 is not recommended in extreme summer
    toofast's Avatar
    Sep 2004
    Chizhou
    18,163
    31 Post(s)
    1+, Try 10w-30
    Even if you are on the right track, you will get run over if you just sit there.
    Oct 2008
    Abbotabad
    29
    166
    I was also thinking da same dat 5-20 would be for cold weather but it was recomended in its manual for +50 degree charlie
    irfansiddique's Avatar
    Oct 2008
    33
    1,765
    12 Post(s)
    switch oil. try havoline.
    bunsira's Avatar
    Jun 2013
    106
    Smile Fuchs Oil
    Quote Originally Posted by Umairaziz786 View Post
    Please use imported German brand Fuchs SuperSyn 5W-40 API SN at Rs.591/L in 4L can. It is available at Fuchs WH in H#33, St# 39 F-6/1 Isd. Ph: 051-2604146. if you are in any other city I can give you addresses of other cities.
    HASCOL PETROLEUM LIMITED (Formerly Hascombe Storage Limited)
