Results 1 to 15 of 15
Thread: OBD Scanner for Axio
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Default OBD Scanner for Axio
    Guys anyone know which protocol Corolla Axio supports? Because OBD-2 doesn't work on it as I've tried with an ELM327 BT device.
    Regards,
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Bump
    Sent from my Nexus 4 using Tapatalk 2
    ChipLoco.com | Anything and everything from the tech world!
    imranuh's Avatar
    Mar 2013
    29
    648
    18 Post(s)
    Same here.. May be 1.5 would work
    Sent from my Nexus 7 using PW Forums mobile app
    Tech_guy's Avatar
    Nov 2012
    Gujrat
    281
    8 Post(s)
    Use hobdrive app torque pro app doesnt work
    Tech_guy's Avatar
    Nov 2012
    Gujrat
    281
    8 Post(s)
    Install hobdrive software or app
    Then go to setting nd select protocol toyota jdm can 21
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Quote Originally Posted by Tech_guy View Post
    Didn't work, tried that app a couple of weeks back and selected those JDM protocols.
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    TorquePro connects with the device but says can't connect to ECU.
    While hobdrive connects with the ELM device as well but doesn't read anything from the ECU, only shows the battery (or ELM device's) voltage.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    COmmon Issue As Most Of Toyota Cars Are Not Supporting ...Issues Connecting Or Sometime SHow False Readings Also
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    The TOYOTA DTS With 3S Works Best With Their Cars
    StrikerX's Avatar
    May 2010
    1,240
    61 Post(s)
    2 Thread(s)
    Quote Originally Posted by SER_GTR View Post
    Yeah, I was hoping I can check certain things @ home... looks like 3S is the only option...
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    It Was A CHINA Play TOY Which Works WIth Some And NOT WIth MANY.....!!
    A Proper OBD-II Scanner Is Not SOmething Everyone Can Afford ....!
  12. #12
    imranuh's Avatar
    Mar 2013
    29
    648
    18 Post(s)
    As I already said Toyota JDM doesn't support those obd2 scanner. Tried on premio, axio and vitz but new success. Tried it on pkdm cars and it worked like a charm on pkdm corolla and civic but not on Suzuki as it has different protocol (obd 1.5)
  13. #13
    meer55's Avatar
    Jun 2009
    Gujranwala
    39
    333
    2 Post(s)
    i have garmin eco route obd2 with garmin 1390lmt gps , it is best with reborn
  14. #14
    meer55's Avatar
    Jun 2009
    Gujranwala
    39
    333
    2 Post(s)
  15. #15
    aftab008's Avatar
    Dec 2011
    37
    facebook/OBDify
