Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 145
Like Tree54Likes
Thread: Engine swap in Toyota Crown From 2JZ-GE to 1G-FE
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    Default Engine swap in Toyota Crown From 2JZ-GE to 1G-FE
    Asslam O Alikum!
    today we started the engine swap previously it was fitted with 2JZ-GE but it was not good in fuel economy but the acceleration and performance was too much. so putting the acceleration and power at a side we decided to put some economy motor in the vehicle. so decided to swap it with the Toyota 1G-FE with ECT transmission. which was donated from the GX100 Toyota Mark 2 2001 model vehicle. folowing are some picture's of the swap. and will update later.
  2. #61
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    when these crowns are offered with different engines they have their own selected differentials too which change the driving torque band, The 2L diesel crowns with 94 hp are a different story because they are diesels which are all about torque.
    But in this case, you are going backwards - you are installing a square engine (no torque at all) into a full option crown sedan (heaviest model) - that too known to be the silliest engines of all - feels dead even when revved. Even in its original X cressida/cresta/mark2/chaser platform was a piece of crap. There was a reason these cars were so cheap to buy compared to the 1JZ counterparts.
    A much nicer option would be to swap a mercedes benz M104 in there. It is beautifully designed and overbuilt to the level of insanity. Punches real hard when you push it.
    the diff is also changed before it was matted with the m302 diff assembly
  3. #62
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    between the word hevier does not matter in the case of crown because it has the difference of just 150 kg if compared with 2001 mark 2
  4. #63
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    for you 150 kg maybe nothing but it does really matter - anyway... its an old body swapped crown, they are now on the same lines of the chiiyattar kirolla (76 corolla) in Pakistan. Everything that can be done has been done to them.
  5. #64
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    hahaaaa you are comparing it with rolaa because you are not in pakistan right now enjoying the rides in texas you are a great man you can say anything. but do you had some experince with 1g series engine's?
  6. #65
    SER_GTR's Avatar
    Nov 2005
    30
    9,734
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by atta1111 View Post
    Calculate Power To Weight Ratio With Torque And Where It Put Torque......!!
    Anyways...Enjoy Your Swap......!! And Do Update Us WITh CNG Hybrid Economy And DLC3 Connector With Complete Readouts
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  7. #66
    SER_GTR's Avatar
    Nov 2005
    30
    9,734
    16
    488 Post(s)
    19 Thread(s)
    This Engine To Me Looks 4AFE With 2 More Cyls.....!!
  8. #67
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    engines open/swap/rebuilt in Pakistan last 1 year. probably from dust
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  9. #68
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    bigger engines last longer than smaller engines
  10. #69
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    yes - these swapped crowns are equal to the old corollas because they have been hacked up into many forms like the old corollas. anyway - I have worked on 1G engines and they are not all that. I would have chosen the 2JZ over the 1G, unless my 2JZ was dead, low compression, rod knock etc.
  11. #70
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    Quote Originally Posted by SER_GTR View Post
    Its a square engine 75x75mm - its a 2 litre 6
    the 4AFE has a wider bore
  12. #71
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    so why not modyfy the 4a in a crown just my idea by the way the ecu comes with this 1G has more aggressive fuel and ignition table as compared to the older ones as we had tested this on road with another crown with 1G
  13. #72
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    already calculated and tested before look in the previous threads you will see the other crown swapped in the end of last month
    take a look https://www.pakwheels.com/forums/eng...a-crown-1992-a
  14. #73
    SER_GTR's Avatar
    Nov 2005
    30
    9,734
    16
    488 Post(s)
    19 Thread(s)
    Bhai Kitna Aggressive Ha....Mukeey Ghonsee Thappar Laatein To Nai Marta Na???
    The Engine Built And Size And Block Built Tells The Story...........ECU Just Can't Make It MAGICAL .....EC-1 Nai Ha ECU Bhai
  15. #74
    SER_GTR's Avatar
    Nov 2005
    30
    9,734
    16
    488 Post(s)
    19 Thread(s)
    Looks Like 1G are Flooded Nowadays So everyone Running for Them.....!!
    2JZ 1jZ Khaap gae sare...!!
  16. #75
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    yep the plethora of 2JZ generators and hiaces are mind boggling now.
  17. #76
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    sab kuch marta hai bhai aap nay chalaya nahe hai is liye bool rahay hain wesay engine ka desighn dekh kar aap kuch guess nahe kar saktay. aur EC1 ko to bhai aap nay dil par lee liya hai>>>>>>>
  18. #77
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    pindi mein 2jz aur1jz kay ambar lagay hain koi nahe leta bhai inhein ab kharcha bhi ziyada aur maintenece bhi.
  19. #78
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    no one swaps the 2jz i hiaces and costers these days hiace walas go for the 3y,4Y,1RZ,2RZ,1TR,2TR,and again for the diesel. and generators are
  20. #79
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    People want an engine that runs 100 kms/lit can move a 1700 kg car to 100 km/h in under 5 seconds and it should run on CNG too, and to top it - its parts should cost a total of Rs 100/- for everything. For them even a lowly honda CD70E is expensive.
  21. #80
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    I have driven a lot of these 1G-FE, 1G-GZE and 1G-GTE X platform cars, they are useless with this engine, they only shine with a 1JZ or 2JZ - the 1G is like bit of a child born with the neighbors wife, its a 2.0L six whose only quality is that its smoother than the 3S but quite a bit weaker too - consumes a bit more fuel as it has more friction than a 4.
    But your money, your car, your game.
    And for God's sake put the engine in a closed room on a stand like a proper workshop.
