Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Xulfiqar
Thread: Changing Differential Assembly Of TOYOTA CROWN 1992
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    Default Changing Differential Assembly Of TOYOTA CROWN 1992
    As we had done the project of swapping this vehicle with the 1G-FE engine now it is the turn of differential assy to be matched with the the powertrain. so here are some picture's of old diff assy
    livilr_invisible's Avatar
    Jul 2011
    40
    yes ur right rear differential should match the gear ratio
    1- False friends r worst than open enemies , 2- Only Youth can change the system
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    Quote Originally Posted by Dhoc_Vtec View Post
    the acceleration and low end and high end performanc was quite well and also the fuel economy was also very impressive from the old one diff but still we had to follow the sequence so decided to change the diff as well from the 1G version of the crown so doing it and had extrem improvement in acceleration and cruising and bit the RPM drop's by 400 on each shift interval quite fast ride as some guy's were saying it will be hard to pull the load. nothing that all going very well.
    Jul 2011
    40
    yes ur right but after changing the differential it will change the gears at right RPM or else it will give bad fuel average and might effect the transmission also
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    old diff and axcels
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    new diff
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    what ratio is the diff, must be a bit taller to compensate for the weak engine.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    btw the old spoiler mounts are a giveaway to this car being a ricer - was that so?
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    yes sir it does compansate for the weak engine but on the new diff the rpm's drop by 400 on each start shift and the car now fly's with power and plus the economy has also improved and plus acceleration is improved by 15% so cannot feel the difference now that we are driving a 2.0 L car still feels like 3.0 satisfied customer.
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    sir cannot understand plz elaborate in simple word's thank's between the crown was offered with 7 different type's of diff assy and the 1G version crown has 3 different diff varaieties one with LSD btw how is your idea about the LSD with it I was asking my father to replace it with that but he didnot recommended me that LSD what is your opinion sir.
    supraman2jz's Avatar
    Jun 2008
    33
    2,697
    76 Post(s)
    Can it do donuts now?
    What xulfiqar is talking about are antennas for CB radio or something.
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    the brackets on the bootlid
