Page 1 of 4 123 ... LastLast
Results 1 to 20 of 77
Like Tree19Likes
Thread: Toyota Fielder Engine Oil (LIQUI MOLY)
    khurramnaseem's Avatar
    Dec 2013
    Rawalpindi
    55
    57
    Cool Toyota Fielder Engine Oil (LIQUI MOLY)
    AoA All,
    I went to the Liqui Moly outlet at I-8 Markaz, Islamabad & i met with an expert Mr Muhammad Anwar (0322 6001841). An expert, & he advised me to use 5W-30 oil for my fielder (it had done 46000 km on its odo meter). First he used "Engine Flush Plus" in the old oil for 10 minutes, then flushed the oil. Added some new 5W-30 Liqui Moly and then added "CERATEC" with more engine oil till the engine oil dip stick showed almost full.
    WOW.....the engine sound ...was no more ..only wheels running on the road.....it was all smooth.....
    He had asked me to get the filter changed (Guard filter after 7-8000 km), but change the engine oil after 10,000 km minimum or after 1 year which ever is first. The ceratec time is 50,000 km.........
    Dec 2013
    Rawalpindi
    55
    57
    the last 2 pics r those items i used
    mfdarvesh's Avatar
    Jul 2007
    2,806
    30 Post(s)
    10,000 KM or One Year, classic ...
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    Whats the price of Dot 3 brake fluid??
    top documentaries " Tears of Gaza"
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    Any Liquimoly outlet in Rawalpindi???
    nom125's Avatar
    Dec 2012
    253
    2 Post(s)
    Quote Originally Posted by khurramnaseem View Post
    Mashallah
    Nice to know their was very quick improvement by using the products you mentioned
    QUESTION About oil change??? he mentioned 10000 km as max interval or minimum interval
    Seeing the improvement I will also be using
    Engine Flush Plus and Fuel System Treatment from now on except for engine oil which will depend on the weather, In summers i will use 10W40 MoS2 and In winters i will be using 5W30 for intervals ranging from 8-10 K km
    I called Mr. Anwar for information regarding use of above mentioned products for my car
    Dec 2013
    Rawalpindi
    55
    57
    call on the number given above or 051-4862502
    Dec 2013
    Rawalpindi
    55
    57
    none,
    only LIQUI MOLY outlet at: Shop # 20, Anique Arcade, I-8 Markaz Islamabad
    Dec 2013
    Rawalpindi
    55
    57
    for vehicles having big engine...oil change time is more....for smaller engines it is less.....
    So if u have 1000-1300 cc car engine then go for oil change after 8-10k KM.....if 2000+cc then 15k KM....thats it...its standard for oils
    Dec 2013
    Rawalpindi
    55
    57
    also try CERA TEC.....its gud for 50k KM
    nom125's Avatar
    Dec 2012
    253
    2 Post(s)
    I did call him and wrote about it after i had a detailed discussion with him
  12. #12
    mashriqain's Avatar
    Jan 2010
    411
    17 Post(s)
    What's the price of the three products that were used? i.e. Engine Flush, 5W30 Oil and CERATEC?
  13. #13
    nom125's Avatar
    Dec 2012
    253
    2 Post(s)
    I have two cars one is 2007 model 41K 660 cc driven Daihatsu Sonica(oil capacity 3L)
    second is 2005 model 55K 1600 cc driven Toyota corolla(oil capacity 4L)
    I inquired about Sonica from him and he said "for 3L engine oil better interval is 8L but can be used till max 10K"
  14. #14
    Dec 2013
    Rawalpindi
    55
    57
    5W 30 engine oil for Rs 3900
    Engine Flush Rs 510
    Cera Tec Rs 2500
  15. #15
    Dec 2013
    Rawalpindi
    55
    57
    the manufacturer says use engine oil 5W30.....rest is ur choice
  16. #16
    Dec 2013
    Rawalpindi
    55
    57
    thanx for the feed backs
  17. #17
    Dec 2013
    Rawalpindi
    55
    57
    Default Toyata Fielder 2007 X G edition specs
    all specs taken out...they were too long
  18. #18
    Dec 2013
    Rawalpindi
    55
    57
    AoA All Fielder lovers/owners,
    I know a shop in Rawalpindi area at Sultan Ka Khoe
    Adil Autos (Mr Lal Khan) he had almost all the fielder items with him....mind it they r (very) expensive......
  19. #19
    Dec 2013
    Rawalpindi
    55
    57
  20. #20
    Dec 2013
    Rawalpindi
    55
    57
