Assalam o alaikum @ all. I want to know does any one have installed CNG in axio/axio fielder ? will CNG works in AXIO as it has cvt transmission.if CNG can b used without any harm to engine and gear which cng kit is best? KINDLY SHARE your views Regards.
I have heard people saying that it damages your gear box.I have had experienced the same with my City Varioso I will not recommend you to go for CNG on AXIO because the gear box costs 180k
i hv also heard the same. but a mechanic told me that now there is device for cvt gear jst like advancer which is used for cvt transmission.
that will be great
Yups
bumb.. any experts opinion or some one using cng in axio :s
CVT gear vehicle can be converted to CNG.but you need MAP 2 emulator and advancer. Remember never attach your TPS with advancer otherwise gear shifting will be disturbed and use advancer/emulator separately.i know mechanic here in Rawalpindi which can do it if guided properly.I had successfully converted Toyota Vitz 2007 model with CVT gear box.PM me if you need further details .
CNG milay gi to savings karo *** na bhai
so axio and vits having same transmission? hv u faced any problem?n whts da cost of emulator and advancer etc
in kpk its available
I bought a manual Axio and installed a CNG. Mileage is great and pick as good as petrol
install sequential injection cng kits of either landi renzo omega or brc sequential . these kits are recomended for these types of cars like vitz 2007 +,etc and used for efi cars. read about these on pakwheels and internet. will cost 70k + but the results will be really gud on cng
these type of cng kits requires any modification ?
In Long Run...Its Disaster You Can Call Upon Engine .....
In Simple Its Not Recommended.....AXIO Have Great Petrol Mileage And Won't Worth Wasting .......
A Proper LPG Kit Is Somewhat Much Better Option
not recommended
CNG is bad for engine health particularly for VVTi engines. Dont spoil AXIOs and other good cars by putting CNG in them.
so its a Big No.
no bro no mods these kits have a seperate rail and injectors for cng like petrol injectors . these kits can be fitted in cars upto 180 hp engines . but get it installed from an authorized dealer. they will provide warranty also. check this link
http://www.landi.it/layout.jsp?idz=60173&idtp=165&lang=3&idprodotto=15
In thailand big cars are using this cng kits in taxis.
these kits are available in landi renzo as well as brc but get it installed from an authorized dealer.
How it is bad for engine health? The vvti xli taxis are all on cng.
Sent from my HTC One V using Tapatalk 2
Have the same question in my mindI have seen Corolla less than 60k km's with screwed up engines whereas i have also seen a Gli which was driven as a taxi in south punjab and it 260k km on the clock but still was going strong we went from Dg khan to Multan
