Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 62
Like Tree16Likes
Thread: Mark X Transmission problem, Experts Plz Guide
    kjsiddi's Avatar
    May 2014
    51
    30
    Default Mark X Transmission problem, Experts Plz Guide
    Assalaam O Alaikum,
    I have purchased a Mark X few weeks later, now I realise that my car is running on 4 gears only although it have 6 speed auto transmission, gears from 1 to 4 shifts normally,
    etc when I m very light on gas (picks it up very lightly) 2nd gear shifts @ speed of 10 km/h,
    3rd gear shifts @ speed of 20 km/h,
    4th gear shifts @ speed of 35 km/h,
    After that it stopped up gear shifting, it runs @60 km/h with 2000 rpm,
    @80 km/h with 3000 rpm,
    @100 km/h with 4000 rpm,
    And becomes very hard on gas, I mean it consume a lot of petrol.
    I have discussed this issue to many mechanics and experts, and done these few things
    1)changed transmission fluid with Toyota T-IV (it gone about 5 liters in the tranny)
    2) cleaned transmissions oil filter
    3) reset ECU many times,
    After resetting ECU it become a normal transmission and changing all 6 gears, but after couple of hours or a day only it again stuck in 4 gears,
    I reset ECU by pulling both battery terminals for some time, after reconnecting battery wires car start in first self but its rpm goes up and down for some time then set around 800 to 900rpm is that right way to reset ECU?
    Experts please guide me how to manage, I also contacted to Toyota showroom on Rashid minhas road I think it is Toyota western and asked them for reprogramming of ECU but thay said we don't deal in mark X, I don't want to go to local mechanics,
    Your help will ne highly appreciated.
    Thanks in advance.
  2. #41
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    why you want to reset the ECU - why not visit some shop having a automotive scanner for fault diagnosis?
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  3. #42
    asif002's Avatar
    May 2015
    15
    5 Post(s)
    Quote Originally Posted by capsat View Post
    cause i heard from someone..that resetting the ECU makes the fuel consumption better and remove all the problems including gear shifting and all these.
  4. #43
    asif002's Avatar
    May 2015
    15
    5 Post(s)
    when changing batteries of these new fangled cars - you are supposed to backfeed the system with a booster pack - if your car has drained all its battery power it may require a full recalibration procedure, like EPS, power windows, sunroof, A/C unit, throttle motor, transmission run and emmissions readiness.
    vai..can you plz explain ..what do i do when i need to change the battery.. what's the procedure... what i know is what they do is only open up the terminals and change the battery..
    should the find the errors in ECU at first by going to any workshop or something else?
  5. #44
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    sir please stop listening to gossip channels of your favorite medium. Only "Agha water class of 'R&D scientists ' talk around such non-sense. Resetting an ECU does not improve performance & fuel efficiency in any 'Vehicle'
    connect a stand by battery in parallel as in Jump starting connectivity - remove the dead battery - install the fully charged new battery - remove the cables. The ECU remain alive all the time n no re-programming / remapping / self-learning is needed.
    - @asif002
  6. #45
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    - @asif002
    Sir
    If ECU is reset during self removal by disconnecting batteries what should a person do than.
    Car is driving fine but do I need to get it reprogrammed? It's been almost 3 to 4 weeks this ECU reset has been done.
  7. #46
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by mwanwar View Post
    Sir
    please goto some shop with an automotive scanner & get it scanned for error codes.
  8. #47
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    This means there might be some error codes? Despite no check engine light
    Another question I tried connecting obd 2 scanner and it was not working with my car but was working with all other car except one santro why is it so
  9. #48
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    question is WHY in the world battery terminals were disconnected in the 1st place - ? alright battery replacement agreed, and now if there is no CEL what is the trouble you are facing. - If there is a trouble the scanner will report if even if CEL is not triggered. [ highly unlikely ] in a JDM Mark-X
    Generic OBD scanners may not scan a random " JDM ECU " in my opinion.
  10. #49
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Well initially power windows were not working which the electrician adjusted it with jugar apparently no other problem was faced
    Battery terminals were disconnected to remove self from car as it needed replacement as car was not starting
  11. #50
    ahmadsahii's Avatar
    Aug 2015
    Default need help
    " I was to change the cell of my Mark X's remote. Took it to a cell changer person, he opened whole the remote instead of the specific portion of cell. After packing back the remote, now the car is not starting. Whenever i put the remote the remote in the slot, the push to start doesn't generate current. I connected the sensor detecting computer to the car, the computer shows fault in the immobiliser of the car, the code of remote doesn't matches the immobiliser code in the car, now any way to fix that?"
  12. #51
    JOJ
    JOJ is offline
    JOJ's Avatar
    Jul 2009
    Peshawar
    35
    344
    2 Post(s)
    Wow that was one big issue. I am going to buy one Mark x and I really need to ko how did you fixed ur car issue. If u r still there plz let us know if that's being repaired and what was the main problem ?? Transmission oil or something else???
    One me thing.. is there any availability of mark x spare parts??? Or not
    What point shall I be looking into before buying one specific car ???
  13. #52
    bobbywalker666's Avatar
    May 2016
    Recently I bought a mark x and I encounter the same problem too.. Can you advise on this issue and how much getting it fixed?
  14. #53
    Ijazzareen's Avatar
    Jan 2013
    51
    11
    Fuel everage of MarkX???
  15. #54
    Nabeel_Ali's Avatar
    Feb 2010
    24
    3,509
    108 Post(s)
    Everyone now just stay away from Mark X. It's dead now.
    Sent from my SM-N920C using Tapatalk
  16. #55
    Newbie Follow
    lukeopuri's Avatar
    Jul 2016
    Default +S- option
    how does the select shift transmission work for Mark X? (+S-)
  17. #56
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Quote Originally Posted by lukeopuri View Post
    U need to put it in s use the lever up n down for up shift n down shift of gears
    Sent from my LG-D855 using PW Forums mobile app
  18. #57
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Plus in s mode car also shifts the gears itself when it reaches predefined rpm
  19. #58
    Newbie Follow
    marcusdubles's Avatar
    Aug 2016
    Default Toyota mark x
    I need your help guys,I recently got an engine for Toyota mark x 2005 model complete with a gear box.I replaced without seperating engine and transmission,I filled the transmission with dextrone ii drove it a day then parked it because the performance was bad. I then replaced the oil with Atf WS as toyota dealers advised.but still my transmission is not okay,when I push into D or R. There is not change felt, the car only moves when u accelerate. AT 80KM/H the engine check light comes ON,when it comes.It then moves at high reves.I need your help, before I changed the dextrone ii oil, the engine check light would come on at 40km/h
  20. #59
    Newbie Follow
    Aug 2016
    Guys I need your help,I recently got an engine complete with the transmission for toyota mark x 2005 model. I replaced complete without seperating them,I filled the transmission with dextrone ii atf. After driving I realised the performance was not good,I parked it and later replaced the oil with 4litre Atf WS as advised by toyota dealers.I then tried again,when i push in D or R.no change is felt,the car only moves when I press the accelerator pedal.at 80km/h the engine check light comes on,before I replaced the oil it was coming at 40km/h.I really need your help guys
  21. #60
    Newbie Follow
    fjnhanna's Avatar
    Sep 2016
    my shift problem started after a battery change what x can i do to restore same settings 2008 Mark x
