Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By killervtec
  • 1 Post By mwm749
Thread: Poor output Mark X lights
    killervtec's Avatar
    Jun 2008
    34
    3,666
    57 Post(s)
    Default Poor output Mark X lights
    Hi guyz,
    Recently purchased mark X. Well right side light in projection housing was not working. Tried to installed other used bulbs but was of no use. Also changed blaster (of course toyota original) but bulb switches off after few seconds.
    Now my electrition installed brand new 55w hid set in projection housing.
    Output is extremely depressing. I think these hid's are not meant to be installed in projection housing.
    I am a little noob in this and want experts to help me out.
    Awaiting response.
    Will post output pics tomorrow
    Regards
    K.V
    Sent from my iPhone 5s using PW Forums mobile app
    ibadaslam872's Avatar
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Can you please post a picture? The ballaster might be faulty.
    Sent from my C2105 using PW Forums mobile app
    Under the Coconut tree
    Bilalicious's Avatar
    Nov 2010
    Rawalpindi
    3,297
    126 Post(s)
    Usually the projector lens require D2S or D2R. The ones given to you by your electrician must be H7 or H11 etc...
    What goes around, comes around.
    killervtec's Avatar
    Jun 2008
    34
    3,666
    57 Post(s)
    Yes the lens require D2S but i dont know what exactly he has installed in them.
    Now the question is from where to get D2S quality bulbs.
    faisalayub's Avatar
    Jun 2011
    Jiddah
    34
    1,509
    54 Post(s)
    Ali bhai ..check this guy may be he can help you .. @KeiWorks12 ... and his thread about ballasts and bulb is https://www.pakwheels.com/forums/bod...ishi-oem-bulbs
    But you must have to check the bulb type used in projectors ....
    Toyota Cressida 1982 GL ... Mazda Cx-9 2009... Toyota Corolla 2007 XLI EXECUTIVE (SOLD)...
  6. 28-06-2014, 02:50 PM
    PakWheeler
    Reason
    Not needed.
  7. #6
    KeiWorks12's Avatar
    Mar 2012
    1,298
    13
    94 Post(s)
    @faisalayub thanks for mentioning me and my thread. @killervtec Bro Mark x has OEM D4S HID headlights. D4S ballasts dont accept D2S bulbs same as D2S ballasts dont accept D4S bulb they turnoff after 5-10 secs. D4S ballasts(Denso/Koito black colored square shaped) and D4S bulbs are very rare and too much expensive. i will advise you to change both the ballasts and bulbs with D2S setup. I have OEM Denso/Koito D2S ballasts and very slightly used OEM Philips and Osram D2S bulbs. A friend of mine was having issues with his D4S headlight on his axio. He is more than satisfied now by having OEM D2S setup and output is much better now.
  8. #7
    killervtec's Avatar
    Jun 2008
    34
    3,666
    57 Post(s)
    Can you quote me price for complete blast and bulbs set. If possible kindly share pics of output also for better understanding.
    Regards,
  9. #8
    KeiWorks12's Avatar
    Mar 2012
    1,298
    13
    94 Post(s)
    Poor output Mark X lights -1437825Poor output Mark X lights -1437828Poor output Mark X lights -1437830 @killervtec I only have this output pics now. but these are also taken from a OEM toyota/lexus D2S projector so output will be most likely the same. price i am PMing you
    thanks
  10. #9
    Newbie Follow
    Maysum's Avatar
    Mar 2011
    Default I need to know the price of D2S system ! You can txt me on 03332052333
    Hello Brother ! Thanx for sharing your experience about this, I need to know the price of D2S system ! You can txt me on 03332052333
    Regards
  11. #10
    mwm749's Avatar
    Mar 2008
    Dubai
    59
    1,160
    29 Post(s)
    Quote Originally Posted by KeiWorks12 View Post
    I wish all the threads would be as enlightening as this .......
    I Dont Drive Fast, I Fly Slowly....
