Results 1 to 12 of 12
Thread: Toyota Rush O/D Light Blinking
    huzaifa.haroon's Avatar
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Default Toyota Rush O/D Light Blinking
    Toyota Rush , O/D light started blinking and car shifts gear on very high rpm with a very heavy jerk not smooth at all! The light comes on and goes off after some startups. Need to solve this issue on urgent basis
    Click here for SOLUTION
    Always respect your parents
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    any maintenance done in recent past ? it could be due to faulty VSS ( transmission speed sensor ), choked transmission oil filter, over aged transmission oil. a scanner is required for correct diagnosis
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,958
    32 Post(s)
    Quote Originally Posted by huzaifa.haroon View Post
    get the car scanned and rectify the problem accordingly
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Thanks but light goes off sometimes!
    Anyone else ? Any suggestion?
    jazibdon's Avatar
    Feb 2014
    24
    498
    5 Post(s)
    I think the transmission calibration needs to be done or the throttle body.
    Sent from my HTC VLE_U using PW Forums mobile app
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Quote Originally Posted by jazibdon View Post
    Transmission works well when there is no light! No throttle body issue its clean! I think some sensor has gone bad!
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    you should get your car scanned and see if you get any clues from it. But I don't trust Toyota 3s dealerships anymore. I almost get ripped off with ABS issue in vitz which they were asking about 150k to fix, and git it fixed in 1k from a private workshop.
    “Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac”
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Quote Originally Posted by gorkan View Post
    Hahhaha! this happens sometimes , you have to be careful!
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    Genyan tau nhi hai , best way is as suggested by others is to get it scanned when u r facing the problem
    Laws r Made to be Broken
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Quote Originally Posted by muradi View Post
    Gari meri nahi hay , kisi aur ki hy lekin , geniun bhi hay , magr unhon ne service walay se engine bay pe pani marwa lya tha and that caused the trouble!
    Now water has evaporated and problem is gone
    Newbie Follow
    frankbig5's Avatar
    Aug 2016
  12. #12
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Quote Originally Posted by frankbig5 View Post
    The issue resolved itself, it occured after engine was washed with pressure water at servive station. When the sensor dried or something which had gone bad dried, it came back to normal
    Sent from my ALE-L21 using Tapatalk
