Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By Xulfiqar
Thread: O/D light is flashing, at random times.
    Newbie Follow
    shahidrafi's Avatar
    Jun 2013
    Question O/D light is flashing, at random times.
    I bought Toyota BB few days back. it's O/D off light has started flashing on and off. It does not do it all the time but it does it everyday from time to time. If I shut the car off and restart the light goes out. It seems like it starts when the engine gets little heat up. It also seems like the gears has started slipping some or some fluctuations / jerks in the drive is observed when the light is blinking. I took it to workshop but they could find some "general fault" and nothing more.
    naveedm32's Avatar
    Sep 2012
    al-Ahmadi
    32
    470
    14 Post(s)
    I have a same problem in my mazda 626 .zulfiqar bro said the transmision is gone. Probablay u and me should start looking for a tranny now
    Sent from my iPad using PW Forums
    hornblower's Avatar
    May 2013
    30
    1,746
    75 Post(s)
    Plz Hook up scanning gadget and plz share return codes here ...... Half the job will be done i.e diagnosing the problem
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by naveedm32 View Post
    your mazda/ford transmission has a known fault with this and it should be tended to without delay to save the transmission from destroying itself. A good scan tool can interrogate it and see whats wrong - in any case the whole transmission is removed and the faults corrected - you cannot do it in place as its very tight on the 626
    The toyota unit is pretty robust and its suffering is a bit alarming - I would recommend pull the codes and correct the faults.
    naveedm32's Avatar
    Sep 2012
    al-Ahmadi
    32
    470
    14 Post(s)
    I really appriciate u r opinian bro but here in kuwait replacing a transmission from a japanies half cut cost cheaper then ( scan+ removal+ fixing , getting new parts+ yet no guranties) and less headache. So for me i am simply surviving with it as it do this once daily. I have a vaccation and home build plan starting next week. Might sell off the car and go for a mitsubishi nativa after i get back here...
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    I believe you have the US built 626 with the ford gearbox
    That is even common here in USA - but the problem with these gearboxes is that nearly every used one will be beat to death - the cars meant for mid east have extra transmission coolers in them to cope with the added heat load. They may still fail.
    that is why a good repair on these gearbox is far better than a swap. You may need to look hard for a good and reliable person who knows how to repair automatic transmissions. Shooting a used gearbox at the car wont solve anything.
    A Pakistani person contacted me to tend to his mazda 626 transmission, his *** story was that he had a mechanic swap in a junked transmission 3 times and every single time he spent a good amount on labor price - and still he had problems.
    He is now thinking of junking the car as the cost of a rebuild + all the costs he has spent before would exceed the value of the car.
    naveedm32's Avatar
    Sep 2012
    al-Ahmadi
    32
    470
    14 Post(s)
    In that case i will start the search for a good gear mechanic. I reaaly love this car as its very clean and tough built. I spent a nice a nice smount and replaced mountings,had paint job and all.
    naveedm32's Avatar
    Sep 2012
    al-Ahmadi
    32
    470
    14 Post(s)
    I think its all because of oil overheating. What if i install an extra cooler. Can i? If yes then how?
    naveedm32's Avatar
    Sep 2012
    al-Ahmadi
    32
    470
    14 Post(s)
    I noticed that problem dies not appear when ac on as both fans are running, in morning and night time as weather is nice.
