Results 1 to 4 of 4
Thread: HELP REQUIRED TOYOTA PRIUS 2007 AC vents?
    sahoo56's Avatar
    Aug 2011
    47
    Default HELP REQUIRED TOYOTA PRIUS 2007 AC vents?
    Aoa, since one month, AC air is no longer blowing out of front vents where the A/C is supposed to blow out of, instead it was blowing out of the defrost vents along the windshield thus fogging out the windshield. Visited indus motors multan but they failed to resolve. \any suggesstions?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    HVAC door control out of order, undo the centre console and lower dash pad and test the actuators there
    sahoo56's Avatar
    Aug 2011
    47
    Checked as per advise, getting no air from central vents even in this settings
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    did you test the actuator motors? did you find any door arm broken?
