Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Haroon_Tarar
  • 1 Post By Xulfiqar
Thread: brake pads query
    MuhammadSallar's Avatar
    Mar 2012
    Rawalpindi
    30
    Question brake pads query
    AlSalamAllikum.
    Need a little help from Pakwheels fellows.
    I own an old model (1991) Toyota Crown Royal Saloon. I have to buy the break pads of this car, as old ones are worn off. Now, I wanted to ask, what would be the price of the pads and is there different types of pad available? If so,what type of pads are good?
    Kindly enlighten me on this matter. I don't know a thing about this
    P.s: tell me the price of four pads.
    "If you are driving at the speed of light and you turn on your headlights, what happens?
    Haroon_Tarar's Avatar
    Mar 2008
    37
    3,213
    6
    178 Post(s)
    visit Mehran Autos Rawalpindi.
    Do not go for anything other than genuine brake pads. no compromise when it comes to brakes
    Mar 2012
    Rawalpindi
    30
    Thanks for your suggestion. And yeah, no compromise when it comes to brakes, that's why I started this thread. But, No body replies here, you made an exception.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    as haroon sb said - always opt for OE brake pads (in this case toyota branded parts) or second choice would be OEM suppliers - akebono etc.
    it is also critical to make sure you service the brakes correctly with correct application of lubricants and pastes, also ensure the brake fluid is completely flushed out every year.
    Mar 2012
    Rawalpindi
    30
    Copy that! Thanks for your suggestions, bhai. I will definitely go for OE brake pads.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    please make sure your mechanic does not use his general "grease ki dibbi" anywhere on the calipers.
    waseef's Avatar
    Apr 2008
    Peshawar
    1,969
    27 Post(s)
    Sir is it for evry car to flush out brake fluid every year?? didnt flushed brake fluid from last 4 years.
    Mar 2012
    Rawalpindi
    30
    Okay, he will be under my nose, but that means kay grease us ko lay kar dayni ho ge, to which grease should I buy? O_o
    Never thought that grease could make a difference. Thanks for informing :')
