Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree1Likes
Thread: toyota premio engine oil reduction
    basitjamil's Avatar
    Apr 2015
    7
    2 Post(s)
    Default toyota premio engine oil reduction
    hi fellows
    i need expert openion from dear members. i have just got toyota premio 2006, 1800 cc. i dont know which oil previous owner used.i change oil with GTX 20w50.i noticed some oil reduction after 1000 km.havent noticed any bad smoke,infact i noticed water throwing from silencer in morning.
    members pls tell me that should i consult mech? is it engine weakness?what should i do.pls give openion.
    thanks
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3990 Post(s)
    94 Thread(s)
    6
    do you have the direct injection engine?
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    water throwing doesn't mean a healthy engine it means that your car's exhaust system is free of carbon and the exhaust inner temperature is very low and the old 2zz (I hope I named it right) had some oil reducing engine nothing to worry about
    basitjamil's Avatar
    Apr 2015
    7
    2 Post(s)
    sir jee sorry i dont know abt direct injection engine.its the one originally in toyota premio 2006, 1800cc. non cvt
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    2006 Premio is VVTI EFI 1800 the every same 2ZR FE engine is now offered in 11 Gen Toyota Corolla 1.8 Grande Variants by Indus Motors. 10W-30 will be fine for the engine. - Please do check the PCV valve incase it is clogged replace it with a NEW item
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    This car has 1ZZ-FE. Pretty badass engine, it had issues with oil reduction but was in early 1ZZ's only. 10W40 would be good if engine has clocked somewhere near 200k. Replace PCV valve cheapest item to solve oil reduction. Use OEM filters. I also have altis which has 1ZZ FE clocked 95k i use 5W40 drain it after 5k and it reduces about 1/2ltr. so this is pretty normal.
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    Quote Originally Posted by capsat View Post
    Capsat, he's already using 20W50 and is consuming engine oil. You have suggested him 10W30. I think it will further add to oil consumption. What you say?
    Don't leave a highway for a byway....
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by basitjamil View Post
    hi fellows
    thanks
    Please quantify what "some oil reduction after 1000 km" actually means. Do you have to add oil constantly between oil changes? Do you notice blue smoke from the exhaust?
    basitjamil's Avatar
    Apr 2015
    7
    2 Post(s)
    actully i recently baught this car,dont know which oil previous owner used,i change with GTX 20w50,noticed abt 1 to mm reductiom on dip stick. den i change it with liqui moli 5w30 coz some body told me that this the best oil for this car,now will see as it has run only 100 km yet.
    i havent noticed any bad r blue smoke from silencer,even on 5 to 6 rpm there was no bad r blue smoke from silencer.
    plz clearify that from exhaust u mean silencer or some thing else?
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    A 1 mm reduction is nothing to worry about. Yes, by exhaust I mean "silencer". Just keep an eye on the level throughout this oil change interval and see what happens.
    basitjamil's Avatar
    Apr 2015
    7
    2 Post(s)
    sir do u think that 5w30 will work and is suitable for this car specially in summer
  12. #12
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by imrananr View Post
    OEM Specs for these VVTI engines in our region is 10W-30, The user manual recommend it . - The Toyota 3S shops are using 10W-30.
    BTW allow me to ask why would oil consumption go high if " 10W-30 " is used ?
    toyota premio engine oil reduction -1566149
  13. #13
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    Sir Toyota dealership even uses 20W50 petron in 2ZR clocked 10k.
  14. #14
    imrananr's Avatar
    Jun 2014
    847
    5
    19 Post(s)
    Well when engine has done considerable mileage, moving parts clearances increase and engine requires overhaul. If overhauling (top or major) is not done, engine starts consuming oil at a quantifiable rate. To prevent this or to reduce this, a THICKER oil than one recommended by manufacturer is used to further drive the vehicle with less oil consumed.
    This is the reason that some manufacturers recommend a thicker oil if the vehicle has done 100,000 KM as compared to a new one. Now our friend here is already using 20W50, the thickest multi grade oil available in market and is experiencing oil consumption. Hence, with thinner oil the oil consumption will increase.
  15. #15
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Ok Thank you for an insight for Lubes
  16. #16
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @basitjamil
    Sir please let us know the milage of your car. And i am surprised no one asked.
  17. #17
    basitjamil's Avatar
    Apr 2015
    7
    2 Post(s)
    @ustaad_007
    sir 1,10000.km
    1lac 10 thousand km on odo meter
  18. #18
    basitjamil's Avatar
    Apr 2015
    7
    2 Post(s)
    @ustaad_007
    sir 1,10000.km
  19. #19
    ustaad_007's Avatar
    Jul 2005
    30
    465
    11 Post(s)
    @basitjamil
    If its 110,000 km done then you are using wrong oil, you should use 5W30 or maximum 10W30 not above then this.
  20. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3990 Post(s)
    94 Thread(s)
    6
    so you are saying the oil control rings get shot at 100,000 kms?
