Results 1 to 3 of 3
Thread: toyota probox auto transmission gives jerks
    Newbie Follow
    amin001's Avatar
    May 2015
    Default toyota probox auto transmission gives jerks
    I had throttle body clean last week.after that my auto tramssion is jerking.mechanic checked for the gear oil it was fine .I want some professional advice.thanks
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Reset the ecu by unhooking negative battery terminal for one to two minutes and put it back.
    Never loose hope in life,every step gives u something.
    tintin1's Avatar
    Jan 2014
    1,829
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Reasons can be many
    Dirty Plugs
    tappets
    electrical circuit
    bad fuel quality
    oils
    water circulation
    etc. etc.
    Only good mechanic can inspect & diagnose the exact reason.
    If its electrical reason, then i know once mechanic who is very talented and very cheap also. in the electrical wiring section i've already posted his contact details.
    Be Addicted To Help Others.
