Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By Owais_Yunus
  • 1 Post By tintin1
Thread: Toyota Probox from 4WD to 2WD
    AhmedAliQureshi's Avatar
    Jan 2012
    Rawalpindi
    7
    Post Toyota Probox from 4WD to 2WD
    I have Toyota 1490 Cc Automatic Probox 2006 4WD.
    4Wd work automatically, I do not have to engage any gears etc. At 20km/h it is on 4WD later it is automatically transferred to 2WD.
    Now I have plans to convert it to 2WD by removing the Shaft.
    Is this a good Idea? If its not then what the good idea ?
    Should I remove the differential and place the other 2WD original rod?
    siraj_7's Avatar
    Jun 2012
    465
    10 Post(s)
    Why do you want to do this?
    Jan 2012
    Rawalpindi
    7
    2 reasons
    1) 2WD has better consumption (currently the machine has 14.5km /L mileage)
    2) 2WD has better resale.
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    14.5km/l from an auto probox isnt bad at all. Dont expect miracles after removing the drive shaft.
    MrUnknown's Avatar
    May 2012
    1,401
    31 Post(s)
    Kash itni average mere manual civic deti hoti
    What's Behind You, Doesn't Matter - Enzo Ferrari
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,793
    94 Post(s)
    8 Thread(s)
    Isn't worth it. IMO 4WD is better. A bonus if you live in hilly areas.
    The men are back. @TGT.
    janleva's Avatar
    Apr 2005
    35
    1,861
    18 Post(s)
    Don't do it man 14 is a superb average
    Past cant be brought back ..but future can be made even better than the Past..if one wants to.. ....
    Lala123's Avatar
    May 2013
    Rawalpindi
    24
    245
    12 Post(s)
    Default Toyota Probox from 4WD to 2WD
    Don't remove the shaft. I heard removing it will increase fuel consumption. I am not sure about it. And you're getting good average
    cherokee's Avatar
    Nov 2006
    49
    52
    Members have given you good suggestions but if you want to try then only remove the shaft without disturbing anything else so that if the milage doesnt improve you can put it back.
    tintin1's Avatar
    Jan 2014
    1,851
    8
    61 Post(s)
    2 Thread(s)
    8
    5
    Quote Originally Posted by AhmedAliQureshi View Post
    14km/l is very good average for 1500cc car in Pak. (because probax has CVT transmissions hence good fuel economy).
    But don’t remove it. Let it be there as it is.
    4wd automatic turns on and that’s main issue.
    Well, can you find some switch or button to keep it off ? this button is available in many jeeps specially older models. So I guess there must be some switch or button for it too. But never go to remove it.
    As far as re-sale is concern. Removing 4wd will bring down cars value when people will know that its original versions comes with 4wd.
    Be Addicted To Help Others.
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    Quote Originally Posted by tintin1 View Post
    Probox/Succeed both had 4 speed automatic transmission CVT was offered after the 2014 facelift
    Also im not sure there is a diff lock because this car has full time 4wd
    P.S removing the shaft wont make your car sell for more as there's a 4wd sticker on the rear windscreen and chassis no is different
    so better leave it as is
  12. #12
    tariqazama's Avatar
    Sep 2005
    36
    158
    dont remove it. it has auto 4wd and engages only when a sensor detects that front wheels are spinning freely,very new technology
Tags for this Thread
