Results 1 to 2 of 2
Thread: TOYOTA CAMRY all lights flickering problem
    itsmystuff6's Avatar
    Apr 2008
    36
    34
    Default TOYOTA CAMRY all lights flickering problem
    AOA Guys,
    I have a Toyota camry 2006 altise V6. For some days now I am facing a light flickering problem.
    Some times All the lights of the car inside out start to flicker.and some times the needles on the odo meeter go haywire also.the engine seems to be running ok but i felt like it looses revs too. when I switch off the car and start it again the problem goes away.but the clock and other calculations get reset with that.For some time the car will run smooth but then the problem comes back again from no where.
    I haven't been able to find an answer on line.
    Has anyone faced this problem before..!!?
    Any senior memebers..!!.. @Xulfiqar..your comments have always helped me.
    best regards
    burhanzaki's Avatar
    Dec 2014
    20
    407
    6 Post(s)
    I guess there might be some power issues check your battery terminals main relay/fuse
