Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Prado 1kz engine problem help me out
    shaheerali007's Avatar
    Feb 2010
    31
    220
    Default Prado 1kz engine problem help me out
    Salam dear pakwheelers i have toyota prado 97 with diesel 1kz te engine. Problem i m facing is oil is coming in intercooler then to throttle body , i have asked my mechanic he said new turbo and new rings r neded to solve this problem. let me give u guys little overview of my engine condition there is some blow but not too much very little oil consumption like 1 liter after every 5000km which i think is due to the oil coming in intercooler and throttle body. I m not facing any issue in driving my prado pickup is excellent no black or white smoke on full throttle fuel average is nice 7km/L . Any expert here plz give me suggestion what to do ,should i go for kabli turbo or new rings ?
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Check turbo boost
    Check play in turbo
    And check ur turbo for leaks !
    These things will tell u about turbo health weather to retain it or not , after correcting ur turbo check engine oil loss after use if no loss no need to open engine and replace rings etc
    Feb 2010
    31
    220
    thankyou salman for kind suggestions, let me know one thing how to check turbo boost and play in turbo. and there is no leaks in turbo bec no oil spill on floor
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Throttle body in diesel engine? Check valve clerance
    Feb 2010
    31
    220
    yes there is throttle body in diesel engine its efi diesel . i think the oil is coming from turbo into intercooler then to throttle body
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    tareen's Avatar
    Feb 2005
    43
    634
    15 Post(s)
    Install an oil catch can/ tank and be at ease. Lots of illustrations are available on net.
    *** Its a SATISFACTION thing. Only DIY guys will understand! ***
    DIYs require Space, Money, Time, Skill & Knowledge....or.......the absence of them
    Feb 2010
    31
    220
    dear tareen i went to buyboil catch can but couldn't find a good one all catch can r just without filter the dnt do there work properly which i have heard do u have any experience of catch can
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    the throttle provided in your engine is for EGR purpose and to reduce stalling shock.
    If you have found oil in your charge cooler and its not a burnt type smell then almost 80% certain that the turbo's seals are leaking, meaning new or rebuilt turbo install.
    to isolate the problem from the blowby - test for liquid oil being pushed out from the tube.
    devils_smile's Avatar
    Feb 2009
    Bonn
    26
    4,584
    171 Post(s)
    6 Thread(s)
    Quote Originally Posted by shaheerali007 View Post
    I have the same problem. Noticed oil around the throttle body where the top mounted intercooler pipe is connected. I plan on taking the intercooler off and clean the tb.
    My 1985 Mercedes Benz W201 190D (DIY's, Detailing and Photo-shoots)
    http://www.pakwheels.com/forums/members-member-rides/207432-my-mercedes-c-class-w201
    Feb 2010
    31
    220
    Xulfiqar bhai thanks for ur expert advice, oil in the throttle body and intercooler is not burnt so ur advice is to replace turbo , i asked many mechanics they said turbo is not repairable so i m thinking to buy a kabli turbo
  12. #12
    Feb 2010
    31
    220
    Quote Originally Posted by devils_smile View Post
    bro let one know one thing installing catch can without filter in it will it work
  13. #13
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Oil consumption could be because of worn valve seals.
    Never loose hope in life,every step gives u something.
  14. #14
    Feb 2010
    31
    220
    Quote Originally Posted by argtr65 View Post
    oil consumption is very high oil is consuming by turbo bec its throwing oil throttle body then to manifold eventual engine consume that oil
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    I can assure you - there is no engine imported from Afghanistan. - so I dont know where you would buy a turbo from Kabul.
    there is a small market selling turbochargers - new and used in Ruby Plaza (next to plaza market) - they sometimes have new assemblies or the repair kits for some turbos - they usually deal in huge industrial units but I have bought new holset and Garett automotive purpose units from there too.
    new turbocharger assembly is not cheap, its price might shock you.
    You can try your luck with a scrap market engine turbo, its a hit or miss - and highly depends on the term of purchase you set with the seller.
  16. #16
    Feb 2010
    31
    220
    i have also heard this kabli turbo name frm mechanic bec this is my first time i m dealing with any used part bec this my first old car purchase. So xulfiqar bhai tell me one this is turbo can b repaired or not
  17. #17
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Bro may be its nt the ryt way but remove the intercooler pipe which goes from turbo to intercooler and see play in the turbine blades if they move with fingers or not
    By kabuli the mechanic means its out of a used engine imported from japan or uae but not used locally
  18. #18
    Feb 2010
    31
    220
    ok thx for the suggestion buddy will try it tomorrow.
  19. #19
    tareen's Avatar
    Feb 2005
    43
    634
    15 Post(s)
    As per updated scenario, if the turbo seals are leaking, there is no use of oil catch can. As that works for fumes from bad valve seats sucked thru breather connecting tappet cover and intake hose.
    Though these cans work well by design to trap droplets that condense and hit the surfaces within tank and long pipe. But yet, it can further be improved by securely tying a wire gauze / mesh or small cloth sock at the end of inlet pipe in the catch can.
  20. #20
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Sir Xulfiqar bhai gave u the best solution go for a complete turbo core swap as turbo from a used engine is a hit n trial I have lost alot of money on it and now put in a new core. @akifjanjua if he has one might be able to help you with core.
    I have also seen a add on olx in Karachi who has turbo cores so u might search olx also
