Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Hassan1991
Thread: 3sge beams fuel emission problem
    mujahidali94's Avatar
    May 2015
    22
    41
    Default 3sge beams fuel emission problem
    I want to ask why is my car emitting unburnt fuel. Bht ziada Fuel use kr rae hy(more than Normal) In desi terms "car kachaa maar rahi hai" thats what mechanic and electrician said... i have the blacktop 3sge beams engine. Kindly suggest me what can i do to solve this and good experienced mechanics in Lahore.
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    Probably Compression leakage
    The first step towards knowledge is to know that WE are IGNORANT
    May 2015
    22
    41
    Quote Originally Posted by Hassan1991 View Post
    So what should i ask the Mechanic to check and what do you think is the solution ?
    Sent from my XT1585 using PW Forums mobile app
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    Quote Originally Posted by mujahidali94 View Post
    Ask him to perform a compression test
    May 2015
    22
    41
    I mean in desi language kia kahu 😂
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    He will understand
    supraman2jz's Avatar
    Jun 2008
    33
    2,700
    76 Post(s)
    I mean in desi language kia kahu 
    Bhai jaan kamprayshan chaik karna hai!!
    "Being between arabs, you call it "Jimmss Yukaan Sagheer", or GMC yukon." - Xulfiqar.
    May 2015
    22
    41
    Quote Originally Posted by supraman2jz View Post
    LoL ok bro.. i will do that
    Thanks
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    i dont think its a compression issue. you should check if the MAP sensor is working properly. if you engine has a MAP (manifold absolute pressure) sensor then you should check its wirring, or if your engine has a MAF ( mass air flow sensor) then check its working. basicaly these engine take MAP or MAF sensor reading and calculate the amount and pressure of air coming in the engine, they then adjust the fuel, injectors and ignition accordingly to make the best AIR/FUEL ratio. right now in your case i think the ECU is not able to know how much air is coming in the enigne so its just dumping all the fuel it can tot he cylinders, hence less air and more fuel and you have KACHRA/ kala dhuan/ unburnt fuel in result.
    so in short, check your AIR sensors/ or oxygen sensor..
    sahk's Avatar
    Feb 2009
    371
    6 Post(s)
    The Blacktop beams is very notorious when I comes to the combustion when the MAF isn't properly set, I've been through it.
    Sent from my A0001 using PW Forums mobile app
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    yeah i know.. not only the Beams. but any toyota engine i think. right now i am fighting with my 1jzgte vvti engine with a MAF sensor. after so many days of effort came to know the sensor is bad. so got a new sensor imported from Ebay.
  12. #12
    May 2015
    22
    41
    Quote Originally Posted by sahk View Post
    Nivevto know bro.. where did you get it done right from ? Any god mechanic to fix it in Lahore . Who actualy know 3sge blacktop ?
  13. #13
    May 2015
    22
    41
    Quote Originally Posted by shezyworld View Post
    Yup i know this one bro coz i have mot put the Oxygen sensor yet.. i only have the MAF on it. How much difference will it make after installing the oxygen sensor bro ?
  14. #14
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    it will make a lot of difference.. right now if you dont have oxygen sensor that means the engine is not geting any data of what is coming out of the exhaust. how can it adjust the air or fuel ratio. you have to put the Oxygen sensor to properly let the ECU set the Ratio. i mean its really important.
    as far as the mechanics are concerned in lahore, their are few but the problem is time. mostly people here doing such work have more projects on their hands than they can handle. which eventually delays every one and you just keep going and coming to the workshop.
    aap workshop k chaker he lagatay rehtay ho, aur kaam bohat he slow hota hey. isliye i prefer doing it my self. but if you still want to know then i would say k check REDLINE guy, go to him or talk to him on phone, he is well into 3sge or 3sgte. he knows these engines pretty well top to bottom. but before you hand over the car to him. decide everything prior to initiation.
    1. total scope of work.
    2. time of project.
    3. cost of project.
    time being the main thing.
Tags for this Thread
