Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 41
Thread: Toyota Premio 1.8 strange sound when accelerating
    furqanalighazi's Avatar
    Jul 2012
    28
    Default NOT SOLVED Toyota Premio 1.8 strange sound when accelerating
    UPDATE # the sound is still there also the sound is audible when car reaches its temperature (middle b/w cold and hot) when car is cold there is no sound and when car is in its temperature the sound can be heard what does this mean?
    AOA. Ramazan mubarak to you all. We recently bought a Toyota Premio and i changed its cvt oil and did basic tuning like cleaning spark plugs throttle body cleaning and oxygen sensor but upon acceleration of car it produces "krrrrr" sound not in neutral but in D or S. Whenever the car is accelerating in 3-4 rpm it produces the sound and when the car is driven on low rpm it does not produce the sound. Also the sound is coming from the very bottom of the car not above. (i think from gearbox area). I checked the oil it is ok and also some otherthings they are also fine but the sound is still coming. the sound is not of knocking. will be looking for suggestions about the problem Regards. will upload the audio of sound as well tomorrow as the car is not with me now. the oil i used was silver tin Toyota original cvti oil 4L
  2. #21
    huzaifa.haroon's Avatar
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    If a CVT transmission oil was not changed on time and it got burnt and then you changed it later then the new oil can cause serious damage to transmission. Hopefully its not that but are you sure that krr krr sound is not engine knocking??
    Sent from my ALE-L21 using Tapatalk
    Always respect your parents
  3. #22
    Nabeel_Ali's Avatar
    Feb 2010
    24
    3,509
    108 Post(s)
    Quote Originally Posted by furqanalighazi View Post
    This happened with my friend's vitz. It usually happens when car starts without cvt oil or the oil may be too old. He ended up changing the gear box :/ the cvt pulleys were damaged.
    Sent from my SM-N920C using Tapatalk
  4. #23
    rashid1834's Avatar
    Apr 2015
    Rawalpindi
    37
    8
    Default Toyota Premio 1.8 strange sound when accelerating
    dignose the vehicle with techstreen tyota dignostic tool and chack error code and live data stream inshaAllah u will find problem
  5. #24
    Jul 2012
    28
    Quote Originally Posted by huzaifa.haroon View Post
    i think so might be the cause but i smelled the oil and it was nothing like burning oil was just dirty after cvti oil change it is performing as new...my friend also have premio 1.8 2010 i have compared it fells nothing different
  6. #25
    Jul 2012
    28
    Quote Originally Posted by Nabeel_Ali View Post
    i did some research before changing the oil and was very cautious of the steps...i took it to toyota as it has same engine as toyota grande and same gearbox so i did not take any chances as cvt is a little risky for regular mechanics
  7. #26
    Jul 2012
    28
    Quote Originally Posted by rashid1834 View Post
    will definetly give it a try also do you know from pindi/isb where can it be done?
  8. #27
    rashid1834's Avatar
    Apr 2015
    Rawalpindi
    37
    8
    whats app me 00968 99181834
  9. #28
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    https://youtu.be/o690DovjDAc
    Watch This
  10. #29
    Jul 2012
    28
    Watch This
    thank u for the info also i did see the old oil which was not as much black as shown in video it was dark red and not smelled like burning also one thing comes in mind that did i use the right oil? ( used Toyota Original tin can cvti oil 4L)
  11. #30
    Jul 2012
    28
    Can ovefilling might be cause? just put a very little extra though not too much
    Toyota Premio 18 strange sound when accelerating -1690212
  12. #31
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Thats the correct oil for CVT which came in new shape i guess. Dark red shouldn't be a problem then.
  13. #32
    Khurram26's Avatar
    Dec 2006
    38
    273
    13 Post(s)
    Nothing to do with CVT or anything. The noise is from your exhaust... probably the cat converter has been removed.
  14. #33
    uzeemujeeb's Avatar
    Dec 2008
    381
    5
    4 Post(s)
    did u also changed the transmission oil filter, the rattle from cvt transmission at certain rpm is most likely dirty oil filter cvt + trans. oil filter shall be changed every 60 ~ 80000 km while the standard atf & filter require change at 40 ~ 60000 kms
  15. #34
    Jul 2012
    28
    Quote Originally Posted by Khurram26 View Post
    got it checked cat isn't removed
  16. #35
    Jul 2012
    28
    Quote Originally Posted by uzeemujeeb View Post
    i didn't change the cvt oil filter as toyota guys themselve said that it is a flat paper like filter which doesn't require to be changed and also i asked few members here they said it would be alright to just change the oil without the filter
  17. #36
    Jul 2012
    28
    inshallah will contact u soon
  18. #37
    Jul 2012
    28
    also i took it to another mechanic in islamabad working at audi he checked the cvt it is all ok and also got the engine diagnosed with toyota scanner no codes whatsoever he doubts that the toyota guys did not refit the spark plugs and coils correctly which is causing the noise... now i will take it to toyota again to inspect this issue
  19. #38
    Ijazzareen's Avatar
    Jan 2013
    51
    11
    what is the difference between Crown royal ,athlete and magistrate
  20. #39
    Jul 2012
    28
    sorry to bother but i have updated the issue in main comment will be thankful for opinions
  21. #40
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    I still think that its engine knocking which happens due to pre combustion try using fuel from a good pump and hi octane and then check.
