Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By VCheng
Thread: FJ Cruiser ABS/VSC/TRAC Lights
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Default FJ Cruiser ABS/VSC/TRAC Lights
    A common failure in certain Toyota models, including the FJ Cruiser, is the intermittent error that turns on the ABS/VSC/TRAC lights on the dash:
    FJ Cruiser ABSVSCTRAC Lights -1713310
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quite often, the solution is to replace the stop light switch:
    FJ Cruiser ABSVSCTRAC Lights -1713311
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    This is an easy, two-minute job:
    FJ Cruiser ABSVSCTRAC Lights -1713312
    FJ Cruiser ABSVSCTRAC Lights -1713313
    FJ Cruiser ABSVSCTRAC Lights -1713314
    Installation is the reverse of removal (one of my favorite phrases).
    Enjoy safe driving with the now-working ABS and Stability Control systems.
    mullahnasruddin's Avatar
    Mar 2015
    52
    What did the stop light switch have to do with the said indicators coming on unnecessarily?
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by mullahnasruddin View Post
    The VSC/ABS CPU needs to know that the brake pedal has been pressed by the switch. The master cylinder pressure switch is also monitored for the voltage change that tells the CPU what is the force on the brake pedal. If there is no or erratic signal from the stop switch but the master cylinder pressure switch shows a change, it sets error code C1246. If changing the stop switch does not clear the code, then the fault is in the master cylinder itself.
    FJ Cruiser ABSVSCTRAC Lights -1713772
    Mar 2015
    52
    Good explanation. Thank you. Though I wonder why the sensor is connected to the light circuit in the first place?
    huraiz's Avatar
    May 2012
    Birmingham
    562
    There's lights can come on if both your brake lights are out,happened to my on Toyota avensis.It took me some time to figure out what the problem was.
