Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By zia1288
Thread: Toyota crown 2003 2jz-fse
    soomro87's Avatar
    Dec 2009
    29
    8
    Default Toyota crown 2003 2jz-fse
    Hi friends . I want to share a problem im facing in my crown 2003 2jz fse. I changed its oil 1600 kms ago. Yestarday i checked its all black . I use mobil 1 5w-50 in it. Oil is prefectly complete at the dot of the stick. Wht can be the problem ? Pick up is slightly less than before. Plugs have become brown on 10000 kms. Wht can be the issue ?? Fuel ? Vaccum sensor ?
    zia1288's Avatar
    Dec 2004
    28
    6,897
    117 Post(s)
    3 Thread(s)
    The oil is doing its work i.e. cleaning the engine. There's nothing wrong with engine oil getting black. It just that ustaads have brain washed majority to believe that black oil = zaya, fazool etc.
    Almost everyone in Pakistan is doing corruption to the extent they can. Our leaders are doing at the level they can do. So why should we complain?
    Maverickiz3d's Avatar
    Jun 2010
    32
    565
    12 Post(s)
    Darkening oil means deposits are being cleaned by the oil. However, in some cases the oil tends to get black faster due to slightly worn out rings.
    tintin1's Avatar
    Jan 2014
    1,851
    8
    61 Post(s)
    2 Thread(s)
    8
    5
    Nothing seems Wrong.
    Synethetic oils do the cleaning job well.
    Did you use first time 5w-50? If yes then which oil you were using before?
    I have Crown with 2JZ Engine. Am using ZIC A+ 5w-20. And after running 500 Km, the oil color is like 50% black.
    BTW, what fuel average its giving?
    Quote Originally Posted by soomro87 View Post
    Be Addicted To Help Others.
    soomro87's Avatar
    Dec 2009
    29
    8
    then y its acceleration is reduced to 65% .............it doesnt give the boost it used to give 5000 kms before.....it had a vaccum sensor issue but i also changed it............problem was solved .....now im again feeling low acceleration ....but no more black smoke during acceleration..........plus im using mobil 1 5w 50 since last 30000 kms
