Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 181 to 200 of 292
Like Tree33Likes
Thread: Toyota Mark X Fan Club
    jaan99's Avatar
    Jun 2005
    Select City
    36
    10,176
    5 Post(s)
    Default Toyota Mark X Fan Club
    Hi guys
    i thought to start Beauty Fan Club. love the car but hope to buy one .
    Share ur ride and collection of Mark-x Info pics etc
    - Toyota Mark - X Fan Club - -512384
    The Toyota Mark X (Japanese:???????X??????) is a mid-size automobile created by Toyota for the Japanese market. The Mark X was introduced in 2004 and is manufactured in Kanegasaki, Iwate, Japan. Also sold in China as the Toyota Reiz, it is available with either a 3.0 L or 2.5 L (215PS/212hp) Toyota GR series V6 engine. The engines offer dual VVT-i (variable valve timing) with gasoline direct injection. The rear-wheel drive models have a 6-speed automatic transmission as standard, and the all-wheel drive models have a 5-speed automatic.
    The Mark X is the successor to the Toyota Mark II, which was first introduced in 1968. Although the vehicle features an impressive interior with quality that can be categorized as a luxury sedan, it is aimed at the middle market.
    Specifications:
    Model : 250G
    Layout : Front-Engined, RWD
    Weight : 1510kg
    Engine Model : 4GR-FSE
    Engine : DOHC Water Cool V6 24 Valves
    Compression Ratio : 12.1
    Capacity : 2499 cc
    Bore x Stroke : 83x77
    Max Power : 158 (kW/rpm) [215hp] / 6400rpm
    Torque : 260 Nm / 3800rpm
    Suspension (Front / Rear) : Double-Wishbone / Multi Link
    Brakes (Front / Rear) : Ventilated Disc Brakes / Disc Brakes
    Fuel Tank : 70 Litres
    Length : 4730mm
    Width : 1775mm
    Height : 1445mm
    Wheelbase : 2850mm
    Tread-Front : 1525mm
    Tread-Rear : 1520mm
    Min Ground Clearance : 150mm
    Standard Rims : 16"
    - Toyota Mark - X Fan Club - -512385
    - Toyota Mark - X Fan Club - -512386
    "The messenger of Allah said: "Islam is to testify that there is no god but Allah and Muhammad is the messenger of Allah, to perform the prayers, to pay the zakat, to fast in Ramadhan, and to make the pilgrimage to the House if you are able to do so." He said: " You have spoken rightly", Jebreel (Gabriel) from Number 2 of "Al-Nawawi's Forty Hadiths."
  2. #181
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Quote Originally Posted by hj2006 View Post
    From where did you found one in good condition ? Karachi ?
    I found mine from Lahore s specs
  3. #182
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Quote Originally Posted by groot-x View Post
    Where is the best place to get your X serviced in Islamabad? I've got a 300G coming... with weeks to wait...
    any simple mods that I can do to pick up a few extra horses? I have read that dropping in a high-flow panel air filter like K&N will not do much.
    I really wanted a 2GR instead of 3GR (since it has 70 extra Hp) and almost bought a Crown Athlete 3.5L, but it was more expensive and had 30,000 more Kms on the clock... I hope I won't find the 3GR lacking in power...
    Don't worry about power it can surprise u anytime with anything
    So also be careful only issue is limited 180 speed
  4. #183
    groot-x's Avatar
    Oct 2015
    33
    Quote Originally Posted by mwanwar View Post
    Don't intent to go anywhere close to 180
    Can't wait... my last car was a front wheel drive VW GTI turbo. Now going to a rear wheel drive V6 naturally aspirated set up, it will be an interesting switch...
  5. #184
    anm767's Avatar
    Jul 2014
    Christchurch
    29
    5
    Hi guys,
    Can you point me in the right direction. I want to connect some daylight running lights. I have Mark X 2005. I was wondering if there are some instructions available for dummies? I found some photo instructions, but pictures are not available anymore.
  6. #185
    anm767's Avatar
    Jul 2014
    Christchurch
    29
    5
    apologies for double post
  7. #186
    anm767's Avatar
    Jul 2014
    Christchurch
    29
    5
    And does anyone know what this is? It is next to the left side head light where there is space for daylight/fog lights. It has light green and pink wires going to it and is attached to the body of the car.
    Toyota Mark X Fan Club -1635362
  8. #187
    KeiWorks12's Avatar
    Mar 2012
    1,296
    12
    94 Post(s)
    Quote Originally Posted by anm767 View Post
    Looks like a sensor to me...most probably the parking sensor.
  9. #188
    arzaam.bhatti's Avatar
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    its the outside temperature sensor i think, the one that displays the temp in the display between the dials.
    If everything is coming your way, you're in the wrong lane!
  10. #189
    mhaderaziz_official's Avatar
    Feb 2014
    15
    1,423
    31 Post(s)
    Its probably the automatic lights sensor if your car has those auto lights.
    The hardest part about moving forward is not looking back.
  11. #190
    anm767's Avatar
    Jul 2014
    Christchurch
    29
    5
    Thank you guys for quick responses. I think I better leave this sensor alone.
    Can you suggest about daylight running lights? I have a relay - 30/87/87a/86/85 and a pair of LED lights with a fuse and a switch that looks cool and fits in a space under the wheel. I have seen different diagrams on a number of forums, is there no consensus on how to do this?
  12. #191
    farazharoon's Avatar
    Apr 2006
    Manshera
    34
    28
    great collection of photos
    http://beautyonwheels.tumblr.com
    http://www.twitter.com/farazharoon
  13. #192
    JOJ
    JOJ is offline
    JOJ's Avatar
    Jul 2009
    Peshawar
    35
    344
    2 Post(s)
    Asalam o alakium brothers.
    I am going to buy one Mark 2005 model. I live in peshawar and the car I have been told about is in Islamabad. I will be going there to see n check the car in two to three days so i wont be having all day for the checking and That's 250g, I have no experience of mark x. I am buying it ciz i like it its a RWD and i love that... and in RWD mark x is the best choice i guess. I was looking for a neat n clean car like no scratches on the interior or external. Well apart from that what things are needed to be checked ? I will ha e max 1 or 2 hours to check and buy, should I take the car for error code checking and car wash so they can lift it up and I can see it? I mean kia check karon ? What are the major issues in this car or any specific faults of this car which we would never want to have??? He's driving it with 19s should i bring it down to 18 inch rims or 19 is fine for it?
    Please guide me.
  14. #193
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Quote Originally Posted by JOJ View Post
    Please guide me.
    Wailkumusalam definitely go for error code and note the error code if any or any stored error code and paste it here I will let u know the details.
    Secondly if he is running on 19s suspension would be gone by now and suspension replacement is expensive around 100k without shocks for replacement.
    Check if any other electrical issues with the car as it is quite advanced in terms of electronics n features
  15. #194
    hammads3's Avatar
    Apr 2014
    361
    5 Post(s)
    What would be price of mark x 250g or 300g in good nick? Considering buying one.
  16. #195
    hammads3's Avatar
    Apr 2014
    361
    5 Post(s)
    Quote Originally Posted by hammads3 View Post
    Bumpp....
  17. #196
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Bumpp....
    2.4 million to 2,8 million
  18. #197
    hammads3's Avatar
    Apr 2014
    361
    5 Post(s)
    Okay thanks ! Still expensive consierdering a 10 year old model no?
  19. #198
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Sir looking at the price tag have a look around what u get as brand new in this amount a civic a corolla
    Mark x is a different leauge using lexsus platform and if I am not wrong using the same transmission used in Toyota 86 plus a 4gr engine with a compression ratio of 12:1
  20. #199
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    And u can get a basic version for 1.8 to 2.2 million above price was for up specs a version and 300g premium
  21. #200
    hammads3's Avatar
    Apr 2014
    361
    5 Post(s)
    Yeah mark x is a different league :d
