Page 8 of 15 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 292
Like Tree33Likes
Thread: Toyota Mark X Fan Club
    jaan99's Avatar
    Jun 2005
    Select City
    36
    10,176
    5 Post(s)
    Default Toyota Mark X Fan Club
    Hi guys
    i thought to start Beauty Fan Club. love the car but hope to buy one .
    Share ur ride and collection of Mark-x Info pics etc
    - Toyota Mark - X Fan Club - -512384
    The Toyota Mark X (Japanese:???????X??????) is a mid-size automobile created by Toyota for the Japanese market. The Mark X was introduced in 2004 and is manufactured in Kanegasaki, Iwate, Japan. Also sold in China as the Toyota Reiz, it is available with either a 3.0 L or 2.5 L (215PS/212hp) Toyota GR series V6 engine. The engines offer dual VVT-i (variable valve timing) with gasoline direct injection. The rear-wheel drive models have a 6-speed automatic transmission as standard, and the all-wheel drive models have a 5-speed automatic.
    The Mark X is the successor to the Toyota Mark II, which was first introduced in 1968. Although the vehicle features an impressive interior with quality that can be categorized as a luxury sedan, it is aimed at the middle market.
    Specifications:
    Model : 250G
    Layout : Front-Engined, RWD
    Weight : 1510kg
    Engine Model : 4GR-FSE
    Engine : DOHC Water Cool V6 24 Valves
    Compression Ratio : 12.1
    Capacity : 2499 cc
    Bore x Stroke : 83x77
    Max Power : 158 (kW/rpm) [215hp] / 6400rpm
    Torque : 260 Nm / 3800rpm
    Suspension (Front / Rear) : Double-Wishbone / Multi Link
    Brakes (Front / Rear) : Ventilated Disc Brakes / Disc Brakes
    Fuel Tank : 70 Litres
    Length : 4730mm
    Width : 1775mm
    Height : 1445mm
    Wheelbase : 2850mm
    Tread-Front : 1525mm
    Tread-Rear : 1520mm
    Min Ground Clearance : 150mm
    Standard Rims : 16"
    - Toyota Mark - X Fan Club - -512385
    - Toyota Mark - X Fan Club - -512386
    "The messenger of Allah said: "Islam is to testify that there is no god but Allah and Muhammad is the messenger of Allah, to perform the prayers, to pay the zakat, to fast in Ramadhan, and to make the pilgrimage to the House if you are able to do so." He said: " You have spoken rightly", Jebreel (Gabriel) from Number 2 of "Al-Nawawi's Forty Hadiths."
  2. #141
    exquisite27's Avatar
    Sep 2006
    Abbotabad
    42
    39
    Asalam o alaikum Akram salman,
    thnx for enlightening me on the shocks issue.
    it means that the shocks of the X I'm talking about needs to be checked from some expert to see if they are fine or not.
    will ask the expert opinion on other issues if they arises.
    thnx all once again for ur valuable input.
  3. #142
    Sep 2006
    Abbotabad
    42
    39
    dear Akram salman,
    i sent u a message, did u get it?
  4. #143
    mhaderaziz_official's Avatar
    Feb 2014
    15
    1,423
    31 Post(s)
    Quote Originally Posted by exquisite27 View Post
    dear Akram salman,
    Yes, I did and thank you.
    Sorry for the late reply as PTCL internet is very slow, even 4MBs that is.
    My name is Hader Aziz, I used my dad's name when I made my ID here on PW
    The hardest part about moving forward is not looking back.
  5. #144
    Sep 2006
    Abbotabad
    42
    39
    thnx dear and noted for future!
  6. #145
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    electronic shock absorber ? it is something new for me . unless you mean electronically controlled suspension in a vehicle which is not part of Toyota Mark X line up; to my knowledge toyota Mark X variants are equipped with double wishbones coil spring independent suspension in front and multi link coil spring independent in rear.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  7. #146
    Sep 2006
    Abbotabad
    42
    39
    well u can term it as electric shocks etc but the experts can throw some light on the point you have raised.
  8. #147
    Sep 2006
    Abbotabad
    42
    39
    Assalam O alaikum, In the quest of a Mark x, So far following three are of note : 250g Sports (Auto parking, push start, black room). 250g standard. (Auto parking, push start). 300g Premium. Full options All above cars are considerably well kept (not 10/10) and have their plus and minuses and will require maintenance on purchase and may range from approximately 100-200k to bring it in top notch condition as a Mark X should be!! Needs ur suggestions with pros and cons on above cars, thnx
  9. #148
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    300g premium n than 250g sports
  10. #149
    Sep 2006
    Abbotabad
    42
    39
    Asalam o alaikum all,
    Mwanwar,, thnx for suggestion.
    Can Anyone share his experience about Mark X tyres! I mean keeping in view the motorway high speed driving, weather and road condition of pakistan, which brand of tyres and specification are best suited for vertiga rims (probably 18" inch size) are recommended??
    will appreciate ur comments,plz
  11. #150
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Wailkumusalam go for traction A and temperature A tyres of any brand
  12. #151
    Sep 2006
    Abbotabad
    42
    39
    can u explain the traction A and temperature A? and where they are written on the tyres? what could be the ideal specifications?
    Comments on 16" vs 18" rim size ,,,,,,,,,pros and cons?
  13. #152
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Always go with size written on door for rims
    Temp A and traction A tyre can go to speed of 240 plus I have lost that table which stated all figures for tyres and its written on front of tyre where siZe n other things are written
  14. #153
    Sep 2006
    Abbotabad
    42
    39
    ok,
    but how need to know the effects of 16" & 18" on road clearance and durability on poor road conditions,,,, as i heard that pits and broken roads effect rims in 18" size?
  15. #154
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    ok,
    I have 18" only issue is noise on broken roads otherwise no issues road clearance is really great infact I find more comfortable in x than a Honda rest when u convert suspension to sports mode response is too good it looks like car is stick to the road with a glue
    Always keep in mind x is a mixture of saloon n sports so if u want pureeee comfort go for crown or e class crown has same engine but different suspension.
    However x was made on Lexus platform
  16. #155
    bewareofdevilz's Avatar
    Jun 2005
    30
    98
    2 Post(s)
    Hey Guys, So I have a 2005(Nov 2005) model 300g premium (Vertiga edition as they say).. It has push start, auto parking etc .. but the auto parking is not working, anyone has any idea how to diagnose it ?
    Also anyway to switch off the irritating passenger side seat-belt beep off ??
    Toyota MarkX Vertiga 300g Premium || Honda Integra RSX DC5 || Toyota Hilux Surf 1998 2.7ltr || Rotary Power | TypeE || GTTi 4efte | Mini Monster..!
  17. #156
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Quote Originally Posted by bewareofdevilz View Post
    What's the issue in auto parking(its a parking assist remember that it does not park by itself)
    Get a seat belt clip and put it in belt buckle but if somebody is sitting on the seat he should wear the seat belt
    Does ur vehicle also has AFS?
  18. #157
    Jun 2005
    30
    98
    2 Post(s)
    Quote Originally Posted by mwanwar View Post
    Yes bro it has AFS & works very well at night on curves, for auto assist I saw some videos on youtube on how its used but i believe maybe the sensors on front & back of the car are not working properly as I put it in reverse, click on autopark but nothing appears on the screen (in the video it shows the left, right arrows should appear for selection of where you want to park like ahead of the car of behind it etc)
  19. #158
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Change its setting from ur pannel somebody might have disengaged parking assist if u have the manual that will also help u to activate it
  20. #159
    Jun 2005
    30
    98
    2 Post(s)
    I dont have the manual, whatever i found on the internet is all in japanese .. even the pannel is in Japanese so dont know how to check for it on there..
    Also do you know where I can get a new remote programmed & made ? The current one is not in a good nick & dont have any spare one bro, plus any idea on enabling the sensors on door panels to work ? Thanks soo much for your input
  21. #160
    mwanwar's Avatar
    Feb 2009
    36
    538
    15 Post(s)
    Which city u r from spare key cost 10k and can be made from any programmable key maker which city u r in
    Which sensors in door panels are not working please elaborate and than I can help u out
    It's in Japanese but explore I did that myself so hopefully u will be able to do it also
